Username Post: Remote transmission cooler        (Topic#361040)
Saddlemaker
Loc: Tucson, Arizona
Reg: 01-21-05
05-20-20 08:47 AM - Post#2794273
Have a 55 Chevy 2dr sedan with a crossflow radiator and air conditioning. The radiator does not have a trans cooler. I don't want to put the remote trans cooler in front of the radiator as I already have the evaporater there. Any suggestions for a good spot that will not block the radiator? Have a built 383 that needs lots of cooling.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-20-20 09:18 AM - Post#2794277
    In response to Saddlemaker
you might find this thread helpful, look it over carefully
on my c4 corvette I needed a larger transmission fluid cooler, space is veery limited, I mounted it under the gas tank inside the spare tire carry compartment
Edited by grumpyvette on 05-20-20 09:19 AM. Reason for edit: No reason given.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
05-20-20 01:36 PM - Post#2794297
Here is what I did for a transmission cooler for my '57 Chevy. It is mounted under the floor outside of the frame on the passenger side. The cooler has a thermostatic switch for the fan. B&M has a nice one that uses a Spal fan and has a built-in thermostatic switch. I added the piece of metal on the front side to help flow air into the cooler when the car is moving. No trouble after 10 years of use. Trans is a 700R4.
Attachment: cooler1.JPG (85.77 KB) 18 View(s)
chevyman
chevyman
Loc: Graham,Texas
Reg: 12-24-02
06-07-20 07:42 PM - Post#2795856
    In response to 5Larry7
My trans cooler setup is about the same as Larry`s. Been running it for over 10yrs now with no problems.
Terry
http://www.cardomain.com/ride/480775/1957-chev role...
vabeach56wagon
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
06-17-20 10:06 AM - Post#2796578
This kind of cooler can run down the side of the frame. There's plenty of room in a '56 to put it as we did. Not true of the '55s.
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
FINIS-55
FINIS-55
Reg: 03-01-13
09-08-20 03:33 PM - Post#2803041
    In response to vabeach56wagon
You can use the aluminum tube like vabeach shows in the picture, just run it under the car away from heat. Should work fine.
Execution time: 0.159 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:56 PM
