Username Post: speakers        (Topic#361039)
68impalass
Loc: sydney, nova scotia , can...
Reg: 12-20-11
05-20-20 08:00 AM - Post#2794269
hello --in my 08 Trailblazer the sound system is stock . the problem is that one time one of the rear speakers will work . another time one of the front speakers will work. but never all of the speakers will work. also where one doesnt work once itll work fine later on . it seems to alternate which speaker will work and which one wont . what gives? has anybody else experienced this ? any advise you can give would be awesome
Edited by 68impalass on 05-20-20 08:04 AM. Reason for edit: No reason given.
05-23-20 05:37 AM - Post#2794529
    In response to 68impalass
Are the speakers stock? Is the radio stock? I've seen the problem in other GM vehicles. The speakers are on their way out. You can pull the radio and check the radio harness.
68impalass
Reg: 12-20-11
05-23-20 05:12 PM - Post#2794576
as far as i know its completely stock . im not an audio expert so i appreciate your advice is there anything i need to know ??
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
05-23-20 06:29 PM - Post#2794581
This happened in the van awhile back but it was isolated to just one speaker - AM static, FM was OK.
I thought it was the stock head unit. So in went a NIB, JVC I had laying around.
Turned out it was the speaker surround that was torn. Ended up replacing the speaker system with some JBL separates.
I would try to put the eyeball on the speakers before anything else.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 05-23-20 06:29 PM. Reason for edit: No reason given.
05-24-20 04:15 AM - Post#2794607
Go here to on how to identify bad factory speakers. The door panel are easy to reach. Remove a door panel and check one or two. My suggestion is to replace stock speakers. The material used goes bad over time.
68impalass
Reg: 12-20-11
05-25-20 02:28 PM - Post#2794794
thanks for the great advise . would you happen to know what size(s) i need to look for?
05-26-20 03:52 AM - Post#2794852
Go here to check all optional sizes. Check your vehicle and installed factory options to find replacements. I normally upgrade in size if possible.
68impalass
Reg: 12-20-11
05-29-20 06:09 PM - Post#2795218
thank you much appreciated . i'll definately check that site out for clarity
Execution time: 0.188 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:37 PM
