Username Post: Where to start? 64 C30 292 9ft Stepside        (Topic#361006)
gunclubchamp
Platinum Supporting Member
gunclubchamp
Loc: South Sarpy County, Nebra...
Reg: 11-19-14
05-18-20 09:17 AM - Post#2794103
My great uncles truck. 44k miles. Motor is not seized, got it to run with a little gas in the carb. Thats it. Now, I have all my other jobs out of the way. I'm dedicated to get this truck back on the road. I don't want to take it to a garage and let someone else get the satisfaction of working on it. I wan't to do it myself, the right way, the correct way. I'm asking for some pointers as to where to start first....like, can I rebuild a fuel pump, or just buy a new one. Do I need to worry about gaskets, or just leave them alone. With 44k miles on it and taken great care of, whats probably worn out or needs attention due to being in storage for over 25 years. Wife is going to let me spend a little money on it now..
1964 Chevrolet C30 Stepside
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
05-19-20 07:52 PM - Post#2794244
    In response to gunclubchamp
You say it's been stored for 25 yrs? Were the tires setting on the ground with all the weight on the wheel bearings, or blocked up off the ground?
If I were you, check brake hoses,and lines, wheel cylinders FIRST, then take it for a ride,and see what leaks. Check ALL fluids(trans,rear,motor oil) If stored on the ground, start looking for wheel bearings,and rear axle bearings (JUST FOR STARTERS)
Also check coolant hoses,belts Not sure about fuel pump...Probably better off buying a new one. That's my 2 cents worth
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Senior Moderator
05-20-20 09:06 AM - Post#2794276
    In response to Lead sled
First and foremost if it's close to running with a little work, I'd tend to the brakes. No efforts towards making it run or drive are a good idea until you're sure the brakes have a chance of stopping it. Even just moving it around to work on it, for example pulling it with a chain/strap/etc. if you need to, are wise until you know you can stop it safely.
gunclubchamp
gunclubchamp
Reg: 11-19-14
05-20-20 01:35 PM - Post#2794294
Edited by gunclubchamp on 05-20-20 01:40 PM. Reason for edit: No reason given.
gunclubchamp
gunclubchamp
Reg: 11-19-14
05-20-20 01:36 PM - Post#2794296
Thanks for the info Lead sled!
gunclubchamp
gunclubchamp
Reg: 11-19-14
05-20-20 01:39 PM - Post#2794299
    In response to someotherguy
Thank you for the info. Breaks are the first thing I am going after.
Execution time: 0.306 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:34 AM
