Username Post: Lower control arm bolt        (Topic#361005)
jfio327
Reg: 04-03-20
05-18-20 07:49 AM - Post#2794095
Hey Everyone,
First post here, looking for some advice. I am in the process of rebuilding my front suspension and noticed that some of the threads on my lower control arm bolts were damaged when I removed them. The new Lower control arms I am installing have spherical bearings, so do you think it would OK to replace those eccentric LCA bolts with Similar size, but standard Grade 8 bolts, washers and nuts?
I know the eccentric bolts help with alignment, but I was thinking the spherical bearings sort of override that.
the install is on a 65 Impala, with LCAs from global west.
Any input is much appreciated, thank you.
Edited by jfio327 on 05-18-20 07:56 AM. Reason for edit: No reason given.
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
05-18-20 08:46 AM - Post#2794099
    In response to jfio327
I'd say no. You absolutely need that alignment capability. Just find a better pair, or attempt to clean them up by running a die over the damage. Good luck regardless.
1967 Grande Parisienne 4DR HT
My Flickr page
SSvert396
Gold Supporting Member
SSvert396
Loc: GA
Reg: 07-19-18
05-20-20 04:34 AM - Post#2794254
I had to replace one of mine also, I got it from Rare Parts...They are expensive!!
Joe
Restoration photo album below
https://www.tryimg.com/album/6DcY
1965 Impala 396 convertible
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
05-20-20 03:49 PM - Post#2794306
PM Me. I have a set of eccentrics sitting on my floor ten years now. It is time for them to go.
59fins
Member #212 "19th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
05-20-20 05:11 PM - Post#2794317
Try www.AMK.com thought I seen them on there a while back?
Bill H.
67 Impala SS
jfio327
Reg: 04-03-20
06-03-20 11:43 AM - Post#2795562
    In response to leon phelps
Thank you, I found a pair on ebay for pretty cheap but the condition of them isnt great. I will keep you in mind if they dont work out.
Sounds like you all recommend using the stock eccentric bolts though, so thank you all.
Execution time: 0.667 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:38 AM
