Username Post: Left Brake Light Not Working        (Topic#360995)
Retired Ron
Loc: Vancouver Island, BC, Can...
Reg: 08-17-19
05-17-20 01:15 PM - Post#2794032
My left brake light on my 64 Impala is not working. The turn signal, backup and tail lights work but just not the brake. There are no problems with the right side. I have checked the bulbs and the brake switch with my meter and everything appears to be all right.
Any suggestions as to a possible solution would be appreciated.
05-17-20 04:47 PM - Post#2794051
    In response to Retired Ron
It is probably the turn signal switch. Check for power on the white wire at the turn signal column connector with the pedal pushed. If you have power there, check the black/pink wire for power.
Power goes from the brake switch through the turn signal switch when left or right turn is not selected.
del.impala
Loc: delaware
Reg: 04-13-11
05-17-20 05:21 PM - Post#2794054
Grounds on socket or bulbs. Clean inside of sockets with 1/2"plumbers wire brush.clean grounds to tail light housing to body.
64ss409
Reg: 12-04-02
05-17-20 05:22 PM - Post#2794055
Like already mentioned, probably the turn signal switch. You might get it working by cleaning the contact points.
Ron
paintman
paintman
Loc: Smoky Mts., Tenn.
Reg: 02-27-12
05-17-20 07:38 PM - Post#2794071
    In response to 64ss409
Had the same issue on my 64. New turn signal switch corrected it.
Rich
1962 Chevy Impala Convertible 283 Auto
1964 Impala SS Coupe 327 250 Auto SOLD
2010 Mustang GT Convertible 5 speed
Retired Ron
Reg: 08-17-19
05-18-20 08:23 AM - Post#2794096
    In response to acardon
Thanks for the information, much appreciated.
Ron
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
05-18-20 12:05 PM - Post#2794117
Make sure you have a dual element bulb in that location.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Retired Ron
Reg: 08-17-19
05-23-20 08:30 PM - Post#2794591
I have checked the white wire and am getting power. The closest to a black/pink wire is black/purple. (I guess it's purple.) It appears everything is OK as far as power is concerned so now I'm left wondering what else I can do.
If the switch requires replacing how difficult a job it it? I'm new at this but am learning real fast. Can you give me any directions/advice on replacing the switch?
Much appreciated.
Retired Ron
Reg: 08-17-19
05-24-20 08:24 AM - Post#2794636
Don: I hope this gets to you as I'm having difficulty in learning the system here.
I have checked the white wire and have power. The closest I have to a black/pink wire is black/purple. I have checked the brake switch & that is ok. If I can assume the switch is faulty & I have to replace it how much trouble is the procedure? My last vehicle was a stock '30 Ford which was a little less complicated than the Chevy but I'm learning fast.
I appreciate your input.
junky
Loc: Northeast CT
Reg: 06-27-10
05-24-20 10:22 AM - Post#2794643
You will need a steering wheel puller. Take pictures as you disassemble the horn, until you are down to the switch. Check the switch for any visual problems. Many times, it is something minor that can be remedied by tightening the switch screws or a broken wire that needs to be repaired. I don't have a 1964, but when I was doing service, before I replaced any part, I started with checking the part for abnormities that were an easy fix.
The most important thing that you will need, and should have before attempting any repair is the factory shop manual(s) and the assembly manual for your car.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
05-24-20 01:57 PM - Post#2794664
    In response to junky
Make sure your socket is grounding properly. If you need to run a sperate wire to a good ground and touch the ground on the socket, some the whole socket is ground and others there is a spring clip where it goes into the housing.
Execution time: 0.322 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:40 AM
