Username Post: Anyone Have a Picture of 65 Impala Danube Blue with Torque Thrust Wheels        (Topic#360945)
stano
stano
Loc: Iowa
Reg: 12-30-00
05-12-20 09:32 PM - Post#2793651
Does anyone have a picture of a 1965 Impala with vintage or not vintage dark center torque thrust wheels on it..
thank you stano
thank you
stano
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
05-12-20 09:46 PM - Post#2793654
    In response to stano
Stano, Google exactly that '65 Impala with Torque Thrust wheels'
I just did and got a lot of images, not all Torque Thrust but certainly quite a few.
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
stano
stano
Loc: Iowa
Reg: 12-30-00
05-13-20 09:34 AM - Post#2793689
    In response to steve65
I did 1965 impala danube blue and torque thrust. and did not get one with the torque thrust. there was one couple of years ago but did see it come back.
Our daughter and husband are going to build one. She saw a club members 65 danube blue when she was about eight or nine and still wants one.
we will keep searching, hopefully get a picture of one.
thank you for your help..
thank you
stano
Edited by stano on 05-13-20 09:38 AM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-13-20 12:27 PM - Post#2793699
Here is mine with American Racing 200S
Attachment: Ins_Right_Side.jpg (205.31 KB) 11 View(s)
stano
stano
Loc: Iowa
Reg: 12-30-00
05-13-20 12:37 PM - Post#2793700
    In response to aghaga
OH yea. that should get her going. I am going to pass it on.. thanks
stano
thank you
stano
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
05-14-20 06:47 AM - Post#2793761
aghaga,
What size wheels are those? I like that look a lot. I've been debating whether to run 16" wheels or 15" wheels, and torque thrust wheels were the wheel I was leaning towards.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
05-14-20 07:22 AM - Post#2793766
    In response to jktucker92
15x8" 4.25"BS steelies on 245/60r15 all 4 with dog dishes on my 66 SS
The only way to fly...
Ted
Edited by brickwhite on 05-21-20 05:50 AM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-14-20 02:50 PM - Post#2793794
15x8 with 4" back spacing
stano
stano
Loc: Iowa
Reg: 12-30-00
05-14-20 03:33 PM - Post#2793801
never saw a 65-66 I didn't like. as far as I am concerned keep the pictures coming..
thank you
stano
pipoca
Loc: Kyle, TX
Reg: 03-20-13
05-20-20 04:11 PM - Post#2794307
aghaga,
The extra backspacing looks great filling out the wheel wells. Is the 4" backspacing in the rear too? My main qualm is the front not filling out.
NOT mine.
stano
stano
Loc: Iowa
Reg: 12-30-00
05-20-20 06:11 PM - Post#2794324
    In response to pipoca
thank you for the picture. I will pass it on to daughter and her husband.
stano
thank you
stano
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-21-20 06:36 AM - Post#2794378
It is the width minus the backspacing that positions the wheel. My wheels are 8" wide with 4" backspacing. This gives you 4" to the inside and to the outside from the mounting face of the wheel and hub. To position a 7" wheel in the same outside location you would need a 3" backspacing. I have the same wheels all around.
pipoca
Loc: Kyle, TX
Reg: 03-20-13
05-22-20 11:54 AM - Post#2794486
Thanks. Your example is with a zero offset though, right?
Edited by pipoca on 05-22-20 11:56 AM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-22-20 01:58 PM - Post#2794494
yes
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-22-20 01:58 PM - Post#2794495
Yes on the 8" with 4" backspacing
65_Impala
Reg: 12-29-02
05-23-20 06:08 AM - Post#2794535
This is not true.
The wheel width is the width to the inside of the bead width.
Wheels are always considered to be 1" wider 9" wider to the outside of the width dimension. This is the width adder that is always used in the industry regardless of the real wheel total width when calculating the wheel backspacing.
The backspacing is measured from the back of the outside width to the wheel mounting face.
So, a 8" wheel with a 4" backspacing is considered to be 9" wide to the outside. The 4" backspacing would mean there is 4" to the inside and 5" to the outside. This wheel would also be considered to have 1" of negative offset.
Your wheels are 8" with 4.5" of backspace if they are centered on the hub face. if would be unlikely to install 8" wheels with 1" of negative offset onto a 65 or 66 Impala and still have the tires clear the fender lips.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-24-20 06:03 AM - Post#2794613
    In response to 65_Impala
Mine are ZERO offset so that would make them 4-1/2" backspacing then. My visualization was the location of the centerline and width of the tire/wheel and its relationship to body/suspension parts.
Execution time: 0.249 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:24 PM
