Username Post: Wanted:1949-1954 Convertible Clutch Adjustment Rod        (Topic#360944)
50chev1067
50chev1067
Loc: New Jersey
Reg: 03-31-12
05-12-20 07:19 PM - Post#2793638
If anyone has modified their 49-54 manual transmission convertible, and no longer needs/wants their original clutch adjusting rod, Group # 0.787 (It is the threaded piece that looks like a boomerang.). It differs in length from the closed body styles. Could you please contact/PM with availability and cost. Thanks Steve
eplantage
Loc: Southern MN
Reg: 03-15-04
05-13-20 12:06 PM - Post#2793695
    In response to 50chev1067
Is the one for a convertible longer or shorter?
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
05-13-20 01:15 PM - Post#2793703
    In response to eplantage
The parts book lists the convertible (part # 3688194) as 7 1/8" long. All the other body styles (part # 3688232) as 6 7/8" long.
50chev1067
50chev1067
Loc: New Jersey
Reg: 03-31-12
05-13-20 01:51 PM - Post#2793706
As mentioned the parts book says it is longer for the convertible. I believe the length difference is in the flattened area of the rod. Thanks.
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-23-20 04:02 AM - Post#2794524
i have 2 clutch rods measuring them with a cloth tape starting at one end following the curve tom the other end it comes out to 7 1/8 is this the way to measure the length you are looking for
50chev1067
50chev1067
Loc: New Jersey
Reg: 03-31-12
05-23-20 03:06 PM - Post#2794568
    In response to STEFAKI
I don't know how the rod is measured, however I have attached a picture of an adjusting rod from a 50 hardtop. I know that the circled flattened part is longer on a convertible. The shorter rod hits on the X part of the frame.
Attachment: Inked49-54_Chevrolet_Clutch_Adjustment_Rod_LI.jpg (404.85 KB) 5 View(s)
On the convertible rod the flattened part (circled) is longer.
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-24-20 05:47 AM - Post#2794612
will look at mine again and see if i have what you looking for give me till this afternoon to get back to you
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-24-20 07:02 AM - Post#2794621
i have 3 rods 2 of them have the flattened or recessed areas measured 1 inch long while the other one has the flattened or recessed area measuring 1 1/8 is this what you are looking for plus after quick wire wheel cleaning found that the larger flat area part has an E stamped on it hope this helps also it is a hair over 7 1/8 inches long measuring end to end with a cloth tape measure i think it is the one you are looking for
Edited by STEFAKI on 05-24-20 08:58 AM. Reason for edit: No reason given.
50chev1067
50chev1067
Loc: New Jersey
Reg: 03-31-12
05-24-20 01:02 PM - Post#2794657
Would it be possible to PM me a picture?
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-24-20 01:47 PM - Post#2794662
send me your phone number all i have is a flip phone AND WILL TRY AND SEND PICTURE all i have is a flip phone i have described the part the best i can if picture does not make it dont know what else i can do i am not real good on computer without help lets see what happens i am away till at least 9:00 andy
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-24-20 01:55 PM - Post#2794663
i have sent you all the correct measurements for the parts plus the size of the recessed area according to your post it should be the right part
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
05-28-20 06:03 PM - Post#2795107
what did you find out from your friend
50chev1067
50chev1067
Loc: New Jersey
Reg: 03-31-12
05-29-20 06:18 PM - Post#2795219
Received this today, wasn't expecting that he would remove it from car. This is from a driver 50 convertible. This is the part that I need. Thanks
Attachment: 49-54_Chevrolet_Convertible_Clutch_Rod.JPG (417.15 KB) 0 View(s)
From 50 Convertible.
Execution time: 0.129 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:37 AM
