Username Post: 4 bolt main block        (Topic#360918)
chnaus
Loc: Upstate:The Real New York
Reg: 04-18-03
05-11-20 10:12 AM - Post#2793515
I have an 88 1/2t, bought 2nd hand and
a 98 3/4t with a target motor,2nd hand.
How can I tell if either has a 4 bolt main block
CH
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
05-11-20 01:47 PM - Post#2793536
    In response to chnaus
You may be able to find out by decoding the block casting #, if not,take the pan off of them and count the main bearing cap bolts
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
05-11-20 09:35 PM - Post#2793570
bore scope through the drain plug hole
elcamino
elcamino
Reg: 03-30-00
05-12-20 03:45 AM - Post#2793577
The targetmaster motors were 4-bolt. The other not likely.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Senior Moderator
05-12-20 07:06 AM - Post#2793585
    In response to elcamino
The Target Master 350 I pulled from a junked squarebody and installed into my '61 shortbed fleetside ran great! When I finally let that truck go as a roller and sold the engine to a friend, he installed it in someone's Caprice, and it promptly sheared off the balancer key from the crank. He took the engine back out and took it apart and discovered it had two completely different heads on it...and both had minor cracks.
Amazing though as it did run great for many thousands of miles.
elcamino
elcamino
Reg: 03-30-00
05-22-20 06:36 AM - Post#2794463
    In response to someotherguy
As a retired flint engine plant foreman (now deceased) once told me many years ago, to paraphrase;
"Back in those days, everyday there were engines that got pulled off the conveyor line for every reason you could think of and got sent to a repair area to be fixed. Sometimes they sat for weeks or months until they were repaired and shipped. So who knows what ended up where??
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:29 PM
