Username Post: 97 K1500 4 wheel ABS spongy brakes        (Topic#360904)
Bowtie_Guy
Bowtie_Guy
Loc: Ohio in the "rust belt"
Reg: 09-04-04
05-10-20 05:09 PM - Post#2793422
I've searched the forum and can't seem to find a good lead on this issue. I replaced three rusted brake lines that were all just after the ABS module under the hood and after bleeding the system (including the module bleeder valve) repeatedly I still have a very spongy brake. If I pump the brake with engine off it builds up nicely and is firm, but of course after the engine runs the booster takes over and it goes most of the way with the "woosh" sound and barely has enough brake. In the recent past I have replaced both rear wheel cylinders, both calipers and countless rusted brake lines all around, and of course the master cylinder once all within the last three years. I haven't readjusted the rear drum brakes lately, but I wouldn't think that would jump out all at once as this seems to be a sudden loss. What could I be missing? Is it possible the ABS module could have gone out? I will admit I just recently discovered the bleeder valve on it and it did have some air in it, but that only got rid of the low brake level light on the dash. I only use the truck as a work truck now so putting huge bucks into the brakes at a mechanic seems over the top as I usually do all my own work once I understand what to look for. Anyone have an idea where to look now?
67' Chevelle SS California car needs much
97' K1500 4X4
72' Nova 350 A/C car (survivor garage kept)
2012 Silverado 4X4 LTZ
05-10-20 05:25 PM - Post#2793424
    In response to Bowtie_Guy
You may have to thoroughly bleed the abs unit, best way is with a high line scanner that controls the internal valves to allow s thorough bleed.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
05-10-20 05:43 PM - Post#2793427
It still wouldn't hurt to check the rear brake adjustment.
Bowtie_Guy
Bowtie_Guy
Reg: 09-04-04
05-10-20 06:10 PM - Post#2793433
I'm guessing you are referring to doing the "auto bleed" of the ABS module. I'm not familiar with the high line scanner, but I have seen videos of scanners that are consumer quality that can perform that function. I will look into that as I can't imagine what a dealer would charge, and since I have another newer truck I could use diagnostic equipment for the future. Thanks
97' K1500 4X4
Bowtie_Guy
Bowtie_Guy
Reg: 09-04-04
05-10-20 06:12 PM - Post#2793435
    In response to 55 Shaker
No, it wouldn't hurt to check again just for piece of mind. I don't know how many more pieces I can afford to lose!
97' K1500 4X4
05-10-20 06:24 PM - Post#2793437
Pro Tip on searching this forum.
Attachment: 2020-05-10_18-17-04.jpg (348.56 KB) 3 View(s)
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-10-20 11:52 PM - Post#2793470
Can you activate the ABS at all?
Greg
'00 Explorer XLT 4.0 V6 Auto
Bowtie_Guy
Bowtie_Guy
Reg: 09-04-04
05-11-20 04:03 AM - Post#2793477
    In response to CowboyTrukr
When you say "activate", as in does it kick in yes it kicks in. If it's slippery, or I'm on gravel and stomp it I feel the feedback through the ABS occasionally, but not as much pedal as I should have.
97' K1500 4X4
junky
Loc: Northeast CT
Reg: 06-27-10
05-13-20 07:40 AM - Post#2793680
A friend had the same problem, and was unable to resolve it, until he found someone that had a pressure bleeder, and bled the system using that. I have no idea why it took a pressure bleeder to resolve the issue, vs. manual bleeding.
Bowtie_Guy
Bowtie_Guy
Reg: 09-04-04
05-13-20 11:36 AM - Post#2793692
    In response to junky
Well, it seems it is all about the distribution block and the ABS module. The block and module can get air trapped in the valves and block, so sometimes the power bleed system can purge the brake system better than having someone pump and bleed the brakes. It also makes it a one man job. I have opted to get an Autel Maxicheck scanner to also go through the "Auto bleed" ABS module purge part of this whole project. For what I would pay for the dealership to do this I'll have my scanner for other vehicles, and I am also looking at the power bleed from Motive Products with the flat adapter to fit these GM rectangular master cylinders. I keep throwing money at it I'll figure it out sooner or later. I had to have something to use my stimulus for.
97' K1500 4X4
streetjust
Chatroom Supporter
streetjust
Loc: Georgia
Reg: 05-14-04
06-29-20 06:27 AM - Post#2797427
I use a bleeder ball from gearwrench to bleed my brakes. I ordered a couple of adapters hoping to find one that fit these master cylinders, but none did. Then I found Power Probe adapter (BA14). It's perfect for these master cylinders! It doesn't seal off the top of the reservoir like we're used to. It has 2 legs that extend through the reservoir down to the master cylinder. I've been using it for a couple of years on both of my '97 K1500 and really like it. It's adjustable so should be able to use it on other vehicles too. Mine is blue anodized so looks pretty nice in addition to being very useful. Hope this helps.
'97 Chevy K1500 & '70 Nova
Edited by streetjust on 06-29-20 06:48 AM. Reason for edit: No reason given.
alpinecrick
Loc: Western Slope of Colorado
Reg: 07-11-17
07-01-20 09:56 PM - Post#2797690
When my 96 K1500 brakes went "whoosh" it was the brake booster leaking.......
Execution time: 0.148 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:27 PM
