Username Post: 1958 impala 2004r trans swap        (Topic#360898)
Meyer
Reg: 11-01-19
05-10-20 09:38 AM - Post#2793393
How much should the front half of the driveshaft be shortened? The car is 100% stock now 283/pg
And what do you do with a crossmember?
ragtp66
Reg: 12-09-07
05-13-20 07:45 PM - Post#2793731
    In response to Meyer
show-cars.com will have both crossmember and the correct length front shaft.
Toys:
1987 Sea Ray Pachanga 22
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
05-23-20 10:14 AM - Post#2794554
    In response to ragtp66
When I installed the OD transmission in place of my stock 3-speed, I simply measured the difference in transmission lengths from the mounting flange to the end of the tailshaft. I took the front driveshaft to a local driveline shop, had them cut out the difference that I measured above, reweld and balance. It fit perfectly with no problems.
'58 Delray 283 3-speed OD
In the family since new
Execution time: 0.251 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:08 PM
