Username Post: max tire size with leveling kit        (Topic#360832)
chevkarl
Reg: 10-01-13
05-06-20 07:47 PM - Post#2793041
I'm going to install a 2" leveling kit on my 2014 Silverado, and I'm not sure the maximum tire size I can go without any rubbing. I'm thinking 285/65's. Any suggestions? My truck has 20" fuel wheels. Thanks in advance.
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
05-07-20 05:11 PM - Post#2793138
    In response to chevkarl
I had 285's on my 14 Sierra with no issues. I wouldn't have gone any bigger due to rub issues on the air dam.
elcamino
elcamino
Reg: 03-30-00
05-11-20 06:41 AM - Post#2793487
Oversize tires are usually much heavier than the tires that come stock, the extra weight and height of the tire will affect performance. The taller the tire, the higher the gear ratio will become. Larger tires will also have a larger rotating mass due to the increase in weight. Both of these issues will result in a loss of low end torque. Your engine will have to strain harder to get the wheels rolling at the start. The smaller the engine, the more it will affect performance and put a strain on all components not to mention up-sizing, or installing a taller tire, will lead to a speedometer reading that is slower than your actual speed. This is because a taller tire will have a larger overall circumference, which will cause it to travel more distance per revolution than the original equipment tire.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Matt
Member #2440
Matt
Loc: SAV
Reg: 09-26-01
05-11-20 10:09 AM - Post#2793514
    In response to elcamino
I have 285/65r20 on my '16 Sierra with 2" level and airdam removed.
I love it. I would do it again with a heartbeat. I did have to ziptie the inner fenders back for clearance.
Performance slightly suffered. MPG slightly suffered. My speedometer was off and it was recalibrated with a diablo programmer.
I am unsure if it'll fit with your wheels. If your wheels have the same backspacing as the factory wheels, then it should fit ok. If your wheels stick out a bit more, it might have rubbing on the inner fender.
Attachment: 1.jpg (313.5 KB) 5 View(s)
Attachment: 2.jpg (343.79 KB) 4 View(s)
Attachment: 3.jpg (334.11 KB) 3 View(s)
Attachment: 4.jpg (84.24 KB) 4 View(s)
Attachment: 5.jpg (256.32 KB) 3 View(s)
chevkarl
Reg: 10-01-13
05-13-20 06:47 PM - Post#2793729
    In response to Matt
Thanks for the pics. I just placed an order for BFG all-terrain tires in 285/65 size.
Matt
Member #2440
Matt
Loc: SAV
Reg: 09-26-01
05-14-20 04:51 AM - Post#2793750
Please do post pics/updates when you have them installed :D
Execution time: 1.219 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:51 PM
