Username Post: Oil feed hole in block        (Topic#360831)
Sean e
Reg: 05-06-20
05-06-20 04:49 PM - Post#2793027
Does anyone know what production date Chevy started casting an 11/32" hole in the block for full flow oil feed to the head, thanks?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-06-20 06:19 PM - Post#2793035
    In response to Sean e
what engine family?
SMALL BLOCK?
BIG BLOCK
W series?
LS series?
if your referring to a sbc?
there are no pressurized oil feed passages to the heads??
oil to the rockers feeds from pushrods
Edited by grumpyvette on 05-06-20 06:28 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
05-06-20 08:26 PM - Post#2793042
What engine family are you asking about?
Pressurized oil fed to the head(s) is typically only used to lubricate overhead cam(s).
Chevy small blocks, big blocks and LS V8's do not have pressurized oil to the head.
Sean e
Reg: 05-06-20
05-06-20 08:31 PM - Post#2793043
    In response to 65_Impala
It’s a 1958 235 eng, oil is not getting to rockers
65_Impala
Reg: 12-29-02
05-06-20 08:50 PM - Post#2793044
1958? Hopefully this helps. Follow the links to see other years.
http://1954advance-design .com/Web%20images/1958-60...
Use of the correct lifters would be the first thing to check.
Sean e
Reg: 05-06-20
05-06-20 11:47 PM - Post#2793052
Thank you very much!!
shadetreemech
Reg: 05-07-20
05-07-20 12:32 AM - Post#2793053
Ok, so I'm working with sean on this project, and in the process of familiarizing myself with the ins and outs of this motor. In a nut shell, while diagnosing some excessive valve clearance on the #1 cylinder, I noticed two issues. The first being lack of oil flow to the top end, and the second being excessive play between the offending rocker and shaft. What I know for sure, is it's a late 58 motor. I have not had a chance to pull the numbers off the head yet, but noticing the crimped off end on the oil supply line, I have to assume it's a 59+ rocker assembly and head. First step is figuring out the oil supply problem, second would be repairing/replacing the rocker shaft and rocker assemblies. To make sure the proper parts are ordered, i need to find the exact date Chevrolet switched to 11/32" oil feed galley in the block. Was it a running production change in 58, or 59, or is there a way to verify the size of the orifice in the casting without pulling the head? Any help is appreciated. Thanks, Chris.
05-07-20 05:36 AM - Post#2793058
    In response to shadetreemech
You might do better in the 58-60 section above. 235 doesn't fit very well in the high performance section. Just kidding, but there are likely more 6 cyl guys there than in this section.
Execution time: 0.123 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 PM
