Username Post: Parking brake switch        (Topic#360822)
Bcrem
Bcrem
Reg: 11-10-12
05-06-20 01:46 PM - Post#2792988
I purchased a switch for the Parking brake on my "59" Impala I looked for the spot to mount it but didn't see one so I removed the housing thinking it may be on the side between the housing and kick panels and no hole for it. The dash gauge is wired I tested the switch and it all works but where the heck do I mount the switch or is the housing not the right one it was on the car when I purchased it could it be that someone put a different housing in the first 2 pictures are of the side between the housing and kick panel the next 2 are of the side that faces the inside and the last is of the switch
Attachment: image.jpeg (181.28 KB) 12 View(s)
Attachment: image.jpeg (112.02 KB) 7 View(s)
Attachment: image.jpeg (177.3 KB) 7 View(s)
Attachment: image.jpeg (143.43 KB) 8 View(s)
Attachment: image.jpeg (193.78 KB) 9 View(s)
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
05-06-20 04:08 PM - Post#2793017
    In response to Bcrem
This is my '60 Impala parking brake. My switch is attached with a clutch head screw and nut. The tab goes in the slotted hole and mounted between the bracket and kick panel. Hope that this helps. Lamar
Attachment: DSC05361_-_Copy_-_Copy.JPG (697.04 KB) 9 View(s)
Bcrem
Bcrem
Reg: 11-10-12
05-06-20 04:48 PM - Post#2793026
    In response to PLS
I’ll check it tomorrow to see if it will work but it seems there is nothing to hold the plunger down could it be missing a part but I will let you know how I make out and thanks
PLS
PLS
Reg: 06-07-12
05-06-20 06:01 PM - Post#2793033
Here's another picture. Lamar
Attachment: DSC04349_-_Copy.JPG (243.71 KB) 12 View(s)
Bcrem
Bcrem
Reg: 11-10-12
05-07-20 06:04 AM - Post#2793061
    In response to PLS
That must be the piece that's missing I'll try to contact southeast chevy to see if they have it anyone out there know of another place let me know. Just hope I don't need a whole new housing
PLS
PLS
Reg: 06-07-12
05-07-20 07:49 AM - Post#2793068
I zoomed in a picture of the bracket and I think that the part the cable attaches to and acuates the switch is all one piece and it looks like it can be replaced since there is a cotter key in the pen that holds it on. Maybe those can be found. Good luck and let us know. Lamar
Attachment: DSC04349_-_Copy__4_.JPG (116.91 KB) 7 View(s)
Edited by PLS on 05-07-20 08:04 AM. Reason for edit: No reason given.
Bcrem
Bcrem
Reg: 11-10-12
05-07-20 04:29 PM - Post#2793130
    In response to PLS
That answers a big question I had I was wondering if it was a piece by itself how it would work but being a 1 piece it all makes sense thanks Lamar you are a great help to a lot of members hang in there and stay safe we need you
Bcrem
Bcrem
Reg: 11-10-12
05-09-20 05:51 AM - Post#2793255
Found one in Minnesota but had to but the whole assembly it should be here by the end of next week maybe I'll restore it and try to recoup some of the cost ???? I'll keep you updated
Jens
"12th Year Silver Supporting Member" & 58-60 Subject Matter Expert
Jens
Loc: Iowa.
Reg: 04-21-02
05-09-20 07:25 AM - Post#2793266
59
Attachment: 7EC27E84-076F-4182-9B55-B1D9039864B4.jpeg (1.9 MB) 9 View(s)
Bcrem
Bcrem
Reg: 11-10-12
05-11-20 07:36 PM - Post#2793564
    In response to Jens
Well from the pics it appears that someone changed the assembly I purchased the car in 1992 and finished the restoration in 2016 that assembly is the one that was on it. I can't understand why they would do that but oh well
Thanks for the info
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
05-12-20 05:30 PM - Post#2793622
Yes sir you have a 60 park brake in yours. Although 59 and 60 will both physically interchange, 60 was an improvement over the 59 as it raised the bottom of the pedal up -out of the way another inch.
Attachment: 23B1DA5B-D368-4849-9AC2-614220985091.jpeg (715.59 KB) 12 View(s)
Attachment: E5724291-99BD-49A4-A117-61C98022EC1E.jpeg (656.97 KB) 7 View(s)
Attachment: 6DF2BA4B-868F-405B-9F79-E30FD684C79C.jpeg (2.74 MB) 7 View(s)
Bcrem
Bcrem
Reg: 11-10-12
05-13-20 04:43 PM - Post#2793718
    In response to Jens
Wow and to think that all this started so I could get the parking brake light on the dash to become functional ???????????? when it'sfinished I'll post some pics thanks to everyone for the information that's why I renew my membership
Bcrem
Bcrem
Reg: 11-10-12
05-26-20 06:58 AM - Post#2794865
Got the part I needed spent the day getting everything cleaned restored and reinstalled works great and again thanks to all who gave valuable information
Attachment: 5AB0E75D-B6A2-48BA-8718-EA85EEF8BD2A.jpeg (64.19 KB) 6 View(s)
Attachment: B8A9FEAA-27AC-4910-A7EA-125A95C61E08.jpeg (75.4 KB) 6 View(s)
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
05-28-20 06:44 PM - Post#2795115
Where did you get the switch?
Bcrem
Bcrem
Reg: 11-10-12
06-08-20 05:51 PM - Post#2795923
    In response to JayChicago
If I remember correctly I think I got it on eBay but when I purchased the part I needed I had to buy the entire assembled and there was one on it but I used the one from eBay and have the other I have not tested it Yet I
Execution time: 0.136 seconds.   Total Queries: 23   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:41 PM
