Username Post: 1955 Chevy 10 bolt rear ended stud?        (Topic#360779)
Disregard 55
Reg: 05-02-20
05-03-20 08:06 AM - Post#2792685
I have a 10 bolt rear that has a broken stud from the housing right on the top. Can this be repaired or does it require a machine shop? Any help would be appreciated.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
05-03-20 10:40 AM - Post#2792693
    In response to Disregard 55
Is this the stock rear end, or a later model with a rear cover, more of what "10 bolt" refers to? Since you said, "stud", I'll guess it's the stock rear end. You'd need to remove the third member, then drive the broken stud out, insert a new one, and seat it using a nut and a stack of washers to pull it in. These studs are usually held in place by serrations on the studs shank. I am Butch/56sedandelivery.
Disregard 55
Reg: 05-02-20
05-03-20 12:24 PM - Post#2792710
You’re correct it is the original, I was unsure what could be done I looked at the parts houses and never saw anything that resembled it. Not sure if I had correct terminology. Thank you for your help
Execution time: 0.188 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 AM
