Username Post: Transmissions & trans mount locations        (Topic#360726)
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
04-30-20 07:09 AM - Post#2792415
On my 67 Impala are 2 trans mount brackets welded to each frame rail. The second ones would locate the trans c/mbr approx 6 inches farther back. Which transmissions would use the front mount & which would use the rear mount? Thanks
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
04-30-20 08:22 AM - Post#2792420
    In response to sz0k30
The rear mounts are used for the Turbo-Hydromatic 400 (TH400) transamission.
The front mounts are used for ALL other transmissions --> 3-speed, Saginaw 4-speed, Muncie 4-speed, Powerglide.
NOTES: All frames had the front mount already installed when delivered from the frame factory supplier to the Chevrolet assembly plant.
The rear mounts were welded onto the frame, on the Chevrolet assembly line only for cars that were to receive the TH400 transmission.
So if your cars frame had two mounts, it was originally equipped with a TH400 transmission.
The TH400 was used behind the 327, 396 and 427 engines,
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 04-30-20 08:24 AM. Reason for edit: No reason given.
sz0k30
sz0k30
Reg: 10-12-08
04-30-20 09:04 AM - Post#2792425
    In response to BigDogSS
Hey BigDog, thanks! That's exactly what I was looking for.
Execution time: 0.179 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:26 PM
