Username Post: 3.55 rearend "rock and knock"        (Topic#360718)
2ndtime50guy
2ndtime50guy
Loc: Midwestern U.S.A.
Reg: 04-06-12
04-29-20 01:34 PM - Post#2792375
Hello friends, from a 49-54 forum guy!
I just finished up my driveline swap on my 1950. I am running my original 216, through a 1955 bellhousing, to a T5 from an S10, with a jeep input shaft to keep my original clutch and pedals, followed by a newly shortened 1955 open driveline driveshaft with an S10 slip yoke and an adapter weld yoke. The driveshaft ties into a 1955 3.55 rearend with new axle bearings.
The rear suspension is a Gambino Notch and 4 link, with Slam Specialties 6" bags and I have a Ridetech air system in the mail.
on the first test drive Monday, the car drives and handles extremely well and I took it easy since I was in my subdivision; not out on the open road.
Here is the hitch. When I slow down for a stop sign or to make a slight turn in the road, I get a light knocking sound from the rear axle. The pinion was set at 3 degrees up when we established ride height and set up the new rearend for welding. In the drive way, I can physically see the rear axle rotate VERY slightly forward and aft when I put the car in motion. This leads me to the following conclusions:
1. The 4 link bolts are a bit loose? I did not torque them excessively, but they are snug with nylon lock nuts.
2. There is play in the preload of the differential. Perhaps that nut needs torqued with a new crush washer?
3. There is excessive lash in the ring and pinion gear? The teeth looked good when I bought it, but I have no idea how to check them with a dial gauge. I do have a good shop here in town that can do this for me.
4. The driveshaft and slip yoke have excessive forward play, i.e. they cut the shaft a bit too short. This would be a real disappointment because they do great work and I do not believe this to be the case.
Any thoughts? I've tried to cover all the bases so that you have all the info you need.
Thanks!
1950 Two Door Styleline Deluxe
>> My Build Thread <<
04-29-20 02:20 PM - Post#2792380
    In response to 2ndtime50guy
If you can SEE movement, #1 is the only possibility. You would not be able to see movement from rear axle/differential problems.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
04-29-20 03:50 PM - Post#2792388
    In response to acardon
Thank you Sir! That is a huge relief. I can definitely snug those down a bit more.
>> My Build Thread <<
WagonCrazy
WagonCrazy
Reg: 06-07-05
04-30-20 06:34 AM - Post#2792413
agree with acardon. Go with the simplest things first. Get that rear end snugged up. Put a gopro camera under there and then take it out for a test drive, then go back and inspect the video.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
04-30-20 10:00 AM - Post#2792429
    In response to WagonCrazy
Thanks! I will check it out!
>> My Build Thread <<
Execution time: 0.108 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:58 AM
