Username Post: spongy brakes        (Topic#360679)
Nezman2000
Reg: 04-16-20
04-26-20 01:59 PM - Post#2792150
I have a 2013 Malibu and the mechanic even showed me pictures of my brake pads which are 80% intact. I feel that they are spongy and a bit weak and it has been 3 years and the mechanic keeps telling me they are good.
Any suggestions or input or? I am just confused if my brake pads are good why do the brakes feel mediocre.
chevkarl
Reg: 10-01-13
05-03-20 11:46 PM - Post#2792739
    In response to Nezman2000
Maybe there's air in the system. Try bleeding your brakes.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-25-20 08:34 AM - Post#2794743
    In response to chevkarl
If you feel they are not right and the current mechanic says they are fine I suggest you get a second opinion.
Did they get spongy over time?
When was the last time they were serviced? Sticking slides over time can cause a spongy pedal as the inner pad will wear and cause the piston to have to move farther than normal.
Another thing could be a failing master cylinder
Old School GM fan FOREVER
Nezman2000
Reg: 04-16-20
06-24-20 11:20 AM - Post#2797095
    In response to rockfangd
ok thanks! I will have another mechanic give me a second opinion.
Execution time: 0.114 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:43 AM
