Username Post: 1972 Pontiac Ventura . Nova Front End        (Topic#360602)
carsmutley
Reg: 11-06-14
04-21-20 03:31 AM - Post#2791664
Hi im looking for a 1972 ish Nova with no luck but have found a solid 72 Ventura. Does the 72 Ventura share the same bodyshell with the 72 Nova other than the front end panels ? If it is the same body shell can 72 Nova front end panels bolt straight onto a Ventura to make it look like a Nova ? Thanks In Advance.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-22-20 12:03 AM - Post#2791742
    In response to carsmutley
The entire front sheet metal/bumper/etc will swap directly. The rear tail light panel is the same, except for the longer Pontiac tail lights, but that can be swapped out also. I imagine the interior is probably a different pattern. I had a 72 Nova SS I bought new, and was one of those cars I should have kept. I too have thought about looking into the Ventura as a "donor" car to build a Nova. Same story with the Olds Omega, and Buick Apollo, along with the Pontiac Ventura; all basically the same, and major parts swap easily. X platform cars. I am Butch/56sedandelivery.
carsmutley
Reg: 11-06-14
04-22-20 08:14 AM - Post#2791767
Many thanks,ive always noticed how similar they are. Once this virus is done (if im still here ) i will pop over from the UK and look for a Nova alternative as they seem to be cheaper than actual Nova s. Do you think there are many Nova s that year in junk yards so i could buy a car and the parts to convert it. ? Thanks
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
07-24-20 02:37 PM - Post#2799440
Just some useless Nova trivia:
N-ova
O-mega
V-entura
A-pollo
davidburns
Reg: 05-23-21
05-23-21 05:11 PM - Post#2820431
Many of the body parts will interchange if you use complete assemblies from the same years. the taillight assemblies are longer on the Ventura, but if you use the whole tail assembly that fits between the trunk lid and rear assembly that works as well. I have changed drum brakes on a 72 to discs from a 73. This works best if you have a disc brake car for a parts car. When I was playing with the Nova/Omega/Ventura/Apollo type X bodies I kept a couple of parts cars around to keep my good one going.
GLHS60
Loc: Alberta, Canada
Reg: 11-19-15
06-10-21 10:48 AM - Post#2821445
    In response to davidburns
Out of curiosity, how do you guys pronounce Ventura.
Ven-tura, Venchura or something else.
Randy
Site Ambassador
06-10-21 07:53 PM - Post#2821461
    In response to GLHS60
Ven-tura. With the end pronounced like the end of mature, but with an a at the end.
1957 Cameo Carrier
Execution time: 0.127 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 PM
