Username Post: Gasoline smelling        (Topic#360601)
rls8836
Loc: North La.
Reg: 01-30-02
04-20-20 08:33 PM - Post#2791652
Every time I run my 55 and park it again in the garage it stinks like gas or a gas oily smell. The carb. and manifold appear dry. Somewhere just recently someone said the same thing and someone posted and said the fuel was sloshing at the gas tank where fuel gauge bolts. And that’s where the smell comes from. What is the consensus on that. I’ll surely drop the tank and replace the gasket if that is the culprit.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
04-21-20 04:19 AM - Post#2791663
    In response to rls8836
That might be where it is leaking. I had to remove my tank and replace the gasket where the sending unit goes into the tank. Sometimes you can access the sending unit in the trunk without removing the tank. There's nothing worse than having your garage stunk up with gasoline smell...
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
04-21-20 06:21 AM - Post#2791673
It is far better to have it smell like kerosene and PB Blaster.
52 Styleline Fourdoor 62 235 PG
rls8836
Loc: North La.
Reg: 01-30-02
04-28-20 08:47 PM - Post#2792329
    In response to gcrkfrd
Thanks for replies guys. Is there a inspection plate in the trunk that I can remove and get to the sender.
niftyfive
Loc: Durango, Colorado
Reg: 02-07-05
05-11-20 07:11 AM - Post#2793489
No inspection cover. You'll need to put it on a lift or stands and creep under. Look directly behind the differential to see the sending unit. Good lighting will help. May be weeping around the gasket. Another problem for leaks is the oring that joins the filler neck to the tank on a 55. Both of these may be leaking so slightly that the gas will evaporate b4 it drips. If not readily visible, use your nose. Don't overlook the drain plug on the tank bottom. After determining one or both post back for assistance as they have their peculiarities.
NIFTYFIVE
Execution time: 0.144 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:15 AM
