Username Post: 84 C1500 starter trouble and mystery block        (Topic#360573)
Motty
Reg: 04-18-20
04-18-20 09:24 PM - Post#2791477
Hello all, I've been doing a LOT of searching and reading and have yet to find an answer. I have an 84 GMC Seirra Classic, 2WD, 700R4. Now, I don't know which block I have. The VIN states it originally came with a 305. However, the man I bought it from said it had a 350. And when I replaced the intake manifold and valve covers, the old valve covers said something about being 350. The smart thing would have been to check the casting numbers at that time, but I didn't know to do it then. (This will all make sense shortly)
Now, the main issue - the starter. I recently started hearing that tell-tale grinding noise coming from the starter. I go to replace it and upon removal of the old one three shims come out with it. I install the new starter (350) and I can't manage to get that 1/8" clearance between the bendix and the flex plate. I shim it every which way including trying to use the old shims and still a no-go. I have tried 350 starters, and 305 starters (all reman from O Reilly). No matter what I do, there just seems to be too much space between the two. I'll get 3-4 good starts and then it'll go back to making that hellacious grinding noise again.
I thought maybe the starter is shifting, so I buy one of the brackets that bolts onto the back of the starter and connects to the block. Well, crawl under there today and neither the block nor the starter have provisions for mounting a bracket in that location. I'm really stumped here and need my truck to run. I'd appreciate any help y'all can manage.
Thanks,
Motty
04-19-20 05:45 AM - Post#2791498
    In response to Motty
Welcome to the board Motty.
Both 350 and 305's use the same starter. All the external parts are interchangeable. The 350 may be a stock GM replacement.
Which bolt patter does the starter have? Are the bolts aligned across or staggered? Does the replacement bolt pattern match or is it universal?
'08 GMC Acadia 3.6L SLE
Motty
Reg: 04-18-20
04-19-20 06:26 AM - Post#2791499
It's staggered. I have a 168 tooth flex plate. The replacement starter is staggered as well, not universal.
04-19-20 08:28 AM - Post#2791511
Ok, the starter and flex plate match. Watch this video on how to measure the tooth gaps.
https://www.youtube.com/watch?v=ucG-yh4oiLU
The 700R4 has the removable lower cover. So the starter might not need to come off. You need a 1/8" drill bit or allen wrench.
Motty
Reg: 04-18-20
04-19-20 11:44 AM - Post#2791530
Totally get that. But no matter how I shim it I can't get the starter bendix close enough to the flex plate. I need to measure but it seems like it's at least a 1/4" space.
04-19-20 05:43 PM - Post#2791555
Is the starter new or old? Bendix are known to stick if grease/lube dries up. Old starters stick too.
This video is for newbies, you can probably skip to take it apart and lube the gear.
https://www.youtube.com/watch?v=RhdSq4WOaDM
Motty
Reg: 04-18-20
04-20-20 09:12 AM - Post#2791590
It'a a reman from Oreilly. Can I still get parts like that from a GM dealer?
04-20-20 10:24 AM - Post#2791595
The starter drive (part that engages) is available on line.
I'm going to move your post over to the Performance Section. You'll get great ideas and more help there.
Execution time: 0.116 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:05 PM
