Username Post: Turn signal components for 53-54        (Topic#360492)
Midi
Loc: Jacksonville, Florida
Reg: 06-04-09
04-11-20 01:10 PM - Post#2790910
I have been searching for the turn signal components for a 53-54 chevy with no luck. I have a 54 steering column that I would like to assemble for installation into a 50 sedan. The existing 50 steering box is in poor condition plus I would like to do away with the Guide signal switch in favor of the factory signals. The parts I need include the turn signal housing, signal lever, and all the rings, springs, and do-dads found inside the housing. I can buy a new switch, horn contact, and steering wheel on line however the other goodies don't seem to be available. SOS (search out stuff)
Edited by Midi on 04-11-20 01:11 PM. Reason for edit: No reason given.
eplantage
Loc: Southern MN
Reg: 03-15-04
04-15-20 05:52 AM - Post#2791189
    In response to Midi
I have sent you an email with a couple of pictures of a turn signal housing. It's complete except the small springs. I would add that a 53-54 column has provision for the turn signal switch wires which a 50 column does not have in case you weren't aware of that. I think the tube is a little larger in diameter and holes are at both ends for the wires. Let me know if you have any interest.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Execution time: 0.09 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:24 AM
