Username Post: Shopping for an Ignition Cylinder        (Topic#360473)
Ray1
Reg: 12-05-03
04-10-20 01:09 AM - Post#2790792
2004 Silverado 1500 4.8 auto 4X4.
Here are the RockAuto options I'm looking at - Link
I've got an automatic trans.
I need a cylinder with keys.
They all have a flat face, instead of the wings that you turn by, which is strange. Seems like it would put more stress on the key and locking mechanism, and be a bad idea.
I'd go with this Standard - Link, except the listing says it doesn't have an accessory position, which is hard to believe.
Standard has a more expensive option with an accessory position (or so the listing says) - Link, so maybe cheaper one actually doesn't?
The AC Delco also says it doesn't have an accessory position. How can that be? It even says it is a four position switch. If it doesn't have an accessory position, shouldn't it be a three position switch?
The WVE says it is a four position switch, and has keys, but it is the cheapest one and usually you get what you pay for.
Can anyone make sense of this?
Edited by Ray1 on 04-10-20 10:40 PM. Reason for edit: No reason given.
redvett01
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
04-10-20 04:10 PM - Post#2790849
    In response to Ray1
You will get more help if you tell us what year, model of vehicle your working on.
K1500 04 Silverado EXT
Ray1
Reg: 12-05-03
04-10-20 10:40 PM - Post#2790872
    In response to redvett01
Done.
Ray1
Reg: 12-05-03
04-13-20 02:08 AM - Post#2791019
    In response to Ray1
So here's a GM cylinder with 5 positions, but no keys - Link
Execution time: 0.109 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:10 AM
