Username Post: Can I pull a 261 oil pan with the engine installed?        (Topic#360466)
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
04-09-20 01:23 PM - Post#2790745
In the process of installing my 261 into our '50 tin woody wagon, I inflicted some small dents in the oil pan. I'd like to tap them out and repaint. Can I drop the pan with the engine installed or must I pull it out? I have access to an indoor lift.
Thanks folks!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
Airlifter
Airlifter
Reg: 06-07-15
04-09-20 01:34 PM - Post#2790748
    In response to mahlmann
I had to loosen motor mount bolts and Jack the engine up a little.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
04-09-20 01:48 PM - Post#2790749
    In response to Airlifter
Yes, you can. It will be easier using a lift than laying on your back in the grass, but I did it once laying on my back in the street. That was many moons ago when I was younger, stronger... and dumber.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
04-09-20 02:24 PM - Post#2790755
Ah shades of 1954, friend and i laid on our backs in Golden Gate Park, San Francisco installing a new clutch in his 50 Merc. He insisted we did not need a clutch alignment shaft as he had one. That turned out to be something of a falsehood. Finally found one in a garage that the guy would lend and got the job done, neither fog nor rain nor the local Police stopped us.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
Execution time: 0.142 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:21 PM
