Username Post: Oil pressure low?        (Topic#360462)
frankthetank
Loc: Lodi California
Reg: 02-22-11
04-09-20 11:13 AM - Post#2790724
Lately I’ve noticed when I fire up my truck the oil pressure is barely at the 40 mark. on the back roads driving at 65 mph it takes a while before it gets up close to the 60 mark. Maybe I haven’t paid attention to it in a while but I could of swore it was usually close to the 60 mark most of the time.
Any ideas what could be the problem?
2006 Silverado 5.3L
203k miles
1963 Chevrolet impala sport coupe
2006 Chevrolet silverado crew cab 2wd
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
04-09-20 11:55 AM - Post#2790732
    In response to frankthetank
As engines wear clearances increase and oil pressure drops. What is your hot engine idle oil pressure?
Rule of thumb is 10 # of oil pressure for 1000 rpm.
frankthetank
Reg: 02-22-11
04-09-20 12:42 PM - Post#2790738
    In response to Tri5man
I’m going to pay attention to the RPMs on my way to work later. Hot engine idle I don’t remember for sure but I want to say 40 I’ll definitely take a look at those two this afternoon.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
04-09-20 01:50 PM - Post#2790750
Info from the Chevy Silverado service manual
Oil Pressure - Minimum - Hot
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
I know we all like to see higher numbers, this is the spec that Chevy uses to determine low oil pressure. My 4.8 (75,000 miles, previously used as a snow plow) shows around 40 psi cruising (around 2000 rpm).
frankthetank
Reg: 02-22-11
04-09-20 02:28 PM - Post#2790757
    In response to george88gta
At hot idle it drops back down to the 40 Mark. Up close to 60 at higher speeds. I’m wondering if it could be a bad oil pump or pick up tube/gasket. Up untill recently I believe it was always close to the 60 mark.
Tri5man
Tri5man
Reg: 06-26-07
04-09-20 02:41 PM - Post#2790760
40 # at idle and 60# at highway speed is fine. I don't believe you have any problems.
frankthetank
Reg: 02-22-11
04-10-20 02:27 AM - Post#2790793
Thanks tri5man. You’ve helped put my mind at ease some.
Execution time: 0.147 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:01 PM
