Username Post: Frame Brackets for Trans Crossmember        (Topic#360452)
Midnight Rider
Midnight Rider
Loc: Brooklyn Ctr, Minnesota
Reg: 01-19-05
04-08-20 03:27 PM - Post#2790669
Hello,
Is there a vendor out there that makes the frame brackets to hang the transmission crossmember?
Since I am planning on pulling my Bel Air body off the frame this spring, I'm laying out some projects to make use of the access. While I don't plan on putting a TH400 in the car, now does seem to be the time to add the right brackets, just in case.
I found the part number; 3855908, in the assembly manual up in the reference section (always very handy!). But my searching so far has turned up a whole lotta nuttin'.
Any suggestions will be greatly appreciated.
Thanks,
Bill
Bill
Midnight Rider
1966 Bel Air 2-door sedan
2007 K-2500
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
04-08-20 07:28 PM - Post#2790690
    In response to Midnight Rider
I don't believe there is very much to them. You could always just make your own? Make some cardboard templates of yours while you have the body off.
Steve65
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
04-08-20 09:57 PM - Post#2790698
Hubbard's Impala Parts sells them.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
04-09-20 07:27 AM - Post#2790712
    In response to carolinakid
Brickwhite is cutting up a frame and offering parts for shipping costs. See the new thread he started.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
pro552000
Reg: 10-09-15
04-09-20 04:33 PM - Post#2790767
    In response to Gaspains
When I installed the 502 and 700R4 trans into my 66Caprice. I bought a G-Force trans crossmember.
It bolts into the original holes on the frame so you don't have to move the brackets. They are a little expensive but worth the money. Here is the link.
https://www.crossmembers.com/
Loren.
Midnight Rider
Midnight Rider
Reg: 01-19-05
04-10-20 05:24 PM - Post#2790857
    In response to pro552000
Steve, CK, Kevin and Loren,
Thanks to all of you for the replies. This site is great! And fairly easy to keep my social distance...
Bill
Midnight Rider
2007 K-2500
Texasray
Texasray
Reg: 11-01-16
04-11-20 12:36 PM - Post#2790905
I found a piece of 6 inch c-channel at a local scrape yard. It was about 2 feet long. I picked it up and asked the guy how much, he said just take it. It is 3/16 steel, main problem was cutting it to fit.
I changed to a T-56 and had to move the location back 8 inches. Back in '96 no one made cross members for Impala's.
Sam
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:51 AM
