Username Post: Fan shield        (Topic#360439)
ufbugman
Reg: 03-23-20
04-07-20 11:46 AM - Post#2790557
I got a project car and the stock fan shield is in 2 pieces , how are they held together welded or am I missing something fan shield for engine
1964 impala 327 auto
Edited by ufbugman on 04-07-20 03:58 PM. Reason for edit: No reason given.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
04-07-20 03:41 PM - Post#2790578
    In response to ufbugman
what year and engine -can't help without this information
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
ufbugman
Reg: 03-23-20
04-07-20 03:53 PM - Post#2790580
64 impala 327
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
04-07-20 07:42 PM - Post#2790610
You must be talking about the fan shroud, not a shield. They were produced in two halves and spot welded together.
Verne
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
04-07-20 08:18 PM - Post#2790616
Perhaps this photo will help.
At the top, you can see where the overlapping halves are spot welded together. This was early in my restoration, and I had just painted the shroud so it stands out nicely. Ignore the engine, it is non-original at this point.
- Dave
1964 Impala 4-door sedan
DCIMPALA
DCIMPALA
Loc: Atlantic Highlands, N.J.
Reg: 10-25-17
04-08-20 06:15 AM - Post#2790632
    In response to dcairns
Also the top flat section should have a letter stamped. My 64 with date stamps in April has letter D stamped on the shroud.
ufbugman
Reg: 03-23-20
04-08-20 05:50 PM - Post#2790675
    In response to DCIMPALA
that the info I needed thank you!
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
04-09-20 11:18 AM - Post#2790726
Doug, good point. I'm doing a 63 and mine also has the letter D. Would have never noticed were it not for your post. Mine was also difficult to discern as it was partially on the roll in the stamping instead of being entirely on a flat surface. Must have been Friday afternoon or Monday morning... Don
Highlander1
Highlander1
Reg: 08-19-04
04-09-20 11:42 AM - Post#2790730
Dave, like your fan/clutch upgrade - or was that part of the AC package? I have a 63 and am adding a seven blade fan and clutch from a 93 Caprice 9C1. In the process I learned that there are at least three different circumferences in the bolt patterns and the 9C3's was greater than either of the two patterns in the original water pump flange. Probably could have elongated them myself but this was no place to screw up and I paid a machinist to do it.
With the fan & clutch installed can you then install the radiator/shield or must the radiator/shield be installed first?
Thanks,
PS Is this the car with the 327/300 engine?
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
04-09-20 01:15 PM - Post#2790743
    In response to Highlander1
That is stock fan blade and stock replacement clutch (Hayden, I think). My car was originally a 283 with AC, so it had the shroud and the 5 blade fan with clutch. The same is true for the 327 with AC (different radiator, though).
I did an experiment with the Heavy Duty variant of the Hayden clutch by modifying a fan blade's mounting holes to fit it. It did move more air, but was incredibly noisy and I think it even hurt performance. So that experiment did not work out well.
HD vs standard clutches (HD on the right)
You can see the original bolt holes on the fan blade, new holes bolted to the clutch.
The shroud must be installed first, then the clutch/fan assembly can be installed.
And yes, this is my 64 that has the 327/300 (bored/stroked to 383) in it now. The picture above is with the old 350 based 383 I had in it from the late 80's.
Old 350 based 383:
New 327 based 383:
- Dave
pvs409
pvs409
Reg: 01-10-05
04-09-20 02:56 PM - Post#2790761
Thanks,
I suggest another better way to install the fan and clutch.
Install the fan and clutch without the radiator and fan shroud in place(much easier than having the fan shroud in the way during installation of the fan and clutch.).
Hang the fan shroud over the fan (with a large towel) then install the radiator and fan shroud at the same time(probably need 4 hands to hold the radiator and fan shroud during installation).
I have done it this way at least 5 times...
Paul
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
04-09-20 07:30 PM - Post#2790775
    In response to pvs409
I agree with Paul's method. But to do it with just 2 hands, make some 5/16-18 studs and screw them into the lower holes in the radiator support. Hang the radiator on them, then hold the top of the radiator with one hand and lift the shroud in place with the other hand. Then start the bolts.
Verne
Execution time: 0.151 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:31 PM
