Username Post: EGR Removal 88 350        (Topic#360430)
Blueseasons
Reg: 10-13-11
04-06-20 03:58 PM - Post#2790513
I am getting a jerky engine and uneven idle and then the "service Engine soon" light comes on. I'm assuming its the EGR valve. Can anybody verify its a 1/2" nut for me? And I cant seem to get a wrench on the nut to loosen it. Just not enough room to get either the closed or the open end on the nut. Am I missing something?
Edited by Blueseasons on 04-06-20 04:01 PM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-07-20 01:00 AM - Post#2790535
    In response to Blueseasons
Let’s save you a bit of heartache. You familiar with how to check your trouble codes?
Greg
'00 Explorer XLT 4.0 V6 Auto
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
04-07-20 05:48 AM - Post#2790541
    In response to CowboyTrukr
I agree, don't assume anything when the trouble codes are easy to check. Another thing he doesn't seem to know, that's probably a metric engine.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
Blueseasons
Reg: 10-13-11
04-07-20 08:34 AM - Post#2790547
I dont have a reader, so its not less trouble. I can get a 13mm socket on the nut, but there is no room to get a wrench on the socket. It seems loose though. If you dont know the nut size. Thats okay. thanks.
Edited by Blueseasons on 04-07-20 08:35 AM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
04-07-20 03:31 PM - Post#2790577
What's a reader have to do with anything? Short the right pins, and count the flashes of the light.
99 K3500 RCLB
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-07-20 11:00 PM - Post#2790624
    In response to 454cid
Checking your trouble codes is very easy. No reader necessary. Just a paper clip and this diagram.
Short A and B. Turn your key on, but do not start it. Count the service engine light flashes. It will give you your codes in two digit sequences. First, it will flash once, then twice. That’s 12. It will do this three times. Then it will cycle through all of the codes and loop back to flashing 12. Twelve is the default code that simply means it’s expecting an ignition pulse and it’s not there.
Attachment: A3CB349D-4C9A-4DD5-9180-BF5D0EA5A43B.jpeg (17.64 KB) 22 View(s)
Greg
Blueseasons
Reg: 10-13-11
04-25-20 05:57 PM - Post#2792081
I'm sorry for not getting back. After getting much worse to the point of the engine almost dying and a couple backfires. My symptoms just went away. But Thanks for this information. I had been led to believe that you do need a code reader in order to get the codes from the reader and the Service Engine Light had to be lighted as codes are not stored with OBD1. I will file this and use it next time.
johnwd98
johnwd98
Reg: 09-05-10
04-26-20 05:15 AM - Post#2792109
If I remember right, codes are stored until one of the battery cables is removed. The computer is then reset.
Execution time: 0.151 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:16 PM
