Username Post: Starting problems        (Topic#360408)
1carguy
Reg: 11-30-08
04-05-20 01:55 PM - Post#2790388
I didn't know if this was the right place to ask this question but I'll give it at try.I've got a tri-five with an early 350/350. Starter wouldn't crank so I replaced it. It's really noisy and after a few seconds of cranking it makes a loud clanking noise. Worse when hot. Got another new starter and same thing. Replaced the battery. Sounds like something is going to come apart, really loud. I shimmed the starter to specs, no difference. I inspected all the ring gear teeth and they look good. I'm wondering if the flex plate is broken? I hate to have the trans removed just to look. Are these flex plates known to crack, is it common?
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
04-05-20 02:08 PM - Post#2790389
    In response to 1carguy
  • 1carguy Said:
I didn't know if this was the right place to ask this question but I'll give it at try.I've got a tri-five with an early 350/350. Starter wouldn't crank so I replaced it. It's really noisy and after a few seconds of cranking it makes a loud clanking noise. Worse when hot. Got another new starter and same thing. Replaced the battery. Sounds like something is going to come apart, really loud. I shimmed the starter to specs, no difference. I inspected all the ring gear teeth and they look good. I'm wondering if the flex plate is broken? I hate to have the trans removed just to look. Are these flex plates known to crack, is it common?[/quote]
Yes and yes.
You might try removing the inspection cover and looking inside.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 04-05-20 02:09 PM. Reason for edit: No reason given.
Member #409
04-05-20 05:41 PM - Post#2790405
A cracked flex plate doesn't usually make for starter noise problems.
The usual symptom is there will be a rapping or clanging noise on moderate acceleration, accompanied by a low frequency vibration or shudder. This occurs at low speeds, like 3-5 mph, and then disappears once you are underway.
Did you buy a starter shim kit at the auto supply and follow the directions in the kit?
04-05-20 10:28 PM - Post#2790432
so it makes the noise only when cranking? are all your battery cables connected clean and strong?
1carguy
Reg: 11-30-08
04-06-20 10:21 AM - Post#2790483
    In response to bobb
No vibration when driving it, seems normal. It happens after cranking it over for a few seconds.Loud clanking sound, like something is coming apart. My first thought is that a couple of teeth on the flywheel are chewed off but not the case. I measured the starter per the instructions and it does not appear to need shims.Brand new battery and cables are clean and tight. It's almost sounds like the bendix drive is smacking the flywheel just when it fires up. Later today I'm going to remove the inspection cover and look closely at the flywheel again.
Edited by 1carguy on 04-06-20 10:53 AM. Reason for edit: No reason given.
04-06-20 08:27 PM - Post#2790529
how big are your battery cables? do they get hot? bigger is better. or you can just double um up
Edited by bobb on 04-06-20 08:27 PM. Reason for edit: No reason given.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
04-06-20 08:45 PM - Post#2790530
    In response to bobb
1carguy:
1. I would remove the coil wire
2. crawl under the car remove the inspection cover.
3. have someone crank the engine and look and see how the starter is engaging the flex-plate.
4. then go from there. Good Luck.
04-09-20 09:17 PM - Post#2790780
if you dont have the bracket on the end of the starter. GET ONE
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:13 AM
