Username Post: Turn Signals not working        (Topic#360403)
Whitetail Hunter
Whitetail Hunter
Loc: Green Bay Wisconsin
Reg: 03-28-15
04-05-20 09:31 AM - Post#2790369
Just started getting the car out of storage. Issue with turn signals dont work. All parking lights do work. When I step on the brakes the signal light on the dash for left turn comes on? But neither left or right signals flash. Not even steady on. Any ideas?
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
04-05-20 09:37 AM - Post#2790370
    In response to Whitetail Hunter
I'm just going to guess everything worked fine before putting it away for the winter (because you are on this site, of course it did). LOL
My guess is you have a ground/corrosion problem from sitting over the winter. Start by checking all the ground connections starting from the back of the car and move forward.
Good luck.
Steve65
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Whitetail Hunter
Whitetail Hunter
Reg: 03-28-15
04-05-20 09:44 AM - Post#2790371
    In response to steve65
UPDATE.....I dont know which plug I screwed with fixed it. But they are working now. LOL
steve65
steve65
Reg: 09-25-13
04-05-20 11:34 AM - Post#2790378
Good to hear, if you can get it outside in the daylight I would still go over all the ground points though. Just to be safe, don't want the lights crapping out while you're driving.
Steve Duncan
66 Impala 2dr Coupe
work in progress
Execution time: 0.106 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:27 AM
