Username Post: '69 Z28 302 motor?        (Topic#360385)
1carguy
Reg: 11-30-08
04-03-20 12:30 PM - Post#2790238
I don't know if this is the right place to ask this question but thought it was a good place to start. I've got a tri 5 Chevy that has what I was told was a mid 80's 350. I have starter problems and was asked to identify which motor it was. The flat surface on the block in front of the right cylinder did not have any numbers stamped so I went to the back of the block and the casting number was 3970010 which I referenced as a 1969 Z28 302. It does not have double hump heads and I'm pretty sure it does not have solids. I really question that this is a 302 motor. Any other way of identifying what motor this is?
1carguy
Reg: 11-30-08
04-03-20 01:09 PM - Post#2790241
    In response to 1carguy
I may have answered my own question....I just found a website that says the 3970010 casting was also used for 1969-1980 350 motors. That's probably what I've got.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
04-03-20 01:24 PM - Post#2790242
According to this:
http://www.1968ss.com/sbcnumbers.asp
That casting could be a 302, 327, or 350.
Pete
Ray P W
Reg: 09-30-15
04-03-20 03:04 PM - Post#2790251
    In response to japete92
1carguy,
I have that same casting number block in my '32 Ford roadster street rod. As Pete says it was used in a variety of displacements and there were 2 and 4 bolt versions of it. A pretty versatile casting, huh?
When I was looking for a core to build into a street rod engine I found mine at, of all places, a Chevy dealer service department. It is a 1978 350 cid 4-bolt truck engine.
Ray W
1carguy
Reg: 11-30-08
04-04-20 07:59 AM - Post#2790287
    In response to Ray P W
Thanks for the input guys. I also looked for a stamped number on top of the block in front of the right cylinder head and there is nothing there, so it's going to be tough to identify this motor. Not knowing what it is makes it a little tougher buying parts for it as I experienced last week buying a starter. You'd think all the sb starters would be the same but not true.
Edited by 1carguy on 04-04-20 08:05 AM. Reason for edit: No reason given.
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
04-04-20 09:00 AM - Post#2790290
Yea, computers have actually made it harder to get parts if you do an engine or tranny swap these days. When I put a NV3500 in my truck, the GM parts counter couldn't give me a part number for the transmission fluid without a VIN number. It used to be when you went to a parts counter and asked for a SBC starter, the person behind the counter would have asked a few questions, like whether it bolted to the bellhousing or engine and then walk back and hand you what you need. These days, their computer system requires them to enter year, make, model, transmission and trim level to give a part number. Today, those motors are all 20+ years old, and I guess they just don't sell that many parts for them anymore. Also the staff are reliant on their computer systems, which don't give a year range for a part, they just give one part number for one application. In reality, there aren't a lot of different starters for a small block chevy, but it's not as easy as it once was for the parts store employees to know the differences.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
04-04-20 12:35 PM - Post#2790299
    In response to jktucker92
Off topic....
Back in the 1980's, I used to work at auto parts stores during summer break while going to college.
This old, grumpy guy (not Grumpy Vette) comes in and asks for a water pump for a Chevy. He refused to give me year, model or engine. He got really irritated and yelled at me, "It don't matter. They're all the same."
I purposely gave him a water pump I knew wouldn't fit...one for a 235 six.
Yeah, he came back about 30 minutes later with the information I asked for.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 04-04-20 12:37 PM. Reason for edit: No reason given.
Ray P W
Reg: 09-30-15
04-05-20 06:44 AM - Post#2790359
    In response to paulo57509
1carguy,
How hard would it be to open a few boxes looking for a starter with either the "straight" or "angled" bolt holes you need?
http://nastyz28.com/threads/why-do-some-s bc-have-a...
I've found parts store personnel to be very helpful in finding parts for odd applications, like radiator hoses with complicated curves and different size ends needed for engine swaps.
Ray W
rumrumm
"19th Year" Silver Supporting Member
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
04-05-20 08:11 AM - Post#2790363
Does your old starter have any identification information on it? If not, as long as you know whether you have a straight or angled bolt starter, you could order one from Summit that will work with either flex plate.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 lb. ft. of torque @ 4300.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
04-05-20 08:41 AM - Post#2790364
  • paulo57509 Said:
Off topic....
I did the same thing to a guy once. Came in being very arrogant. Wanted a water pump for a 427 Chevy. Wouldn't tell me the year or model. I sent him trucking with the short small block water pump used on a C60 truck tall deck 427. Needless to say he came in and asked for the manager on duty which was me. He said I asked for a big block 427 pump not a small block pump. I explained to him the small block pump is the pump for a 427 in a truck application. You never would tell me what you where working on so I assumed it was a big truck. Never had an issue with that guy providing information after that.
elcamino
elcamino
Reg: 03-30-00
04-06-20 03:14 AM - Post#2790438
No such thing as a "302 block" - it's the same block used for many other applications; the only thing that makes it a "302" is the crank, rods, pistons, cam, and heads assembled to it, and the suffix code stamped on the pad later - there's nothing "special" about the block.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
YOUNG57
Loc: Tennessee
Reg: 12-06-10
04-09-20 01:12 PM - Post#2790742
Take your starter to the parts store and ask for another one like it.
Execution time: 0.115 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:28 AM
