Username Post: Why did my Powerglide just Puke?        (Topic#360382)
mr_mahoney
mr_mahoney
Loc: Indiana
Reg: 02-13-03
04-03-20 10:46 AM - Post#2790218
Our "52 chevy has a 1953 powerglide in it that was rebuilt about 15 years ago and has ran great for many years. It was carried on a trailer in "Park" and strapped down for about an hour trip (each way) Upon arrival, there was trans fluid on the trailer bed floor. We checked fluid levels and added as needed. The car drove and shifted fine. It has been fine with no issues and no dripping since. Until the other day, it was backed out of the garage and parked. Upon leaving later, there was trans fluid on the ground. The garage floor was dry. Question: how can we determine if there is a need of repair or what seal or gasket may need replaced?
1952 Chevrolet Convertible
mr_mahoney
mr_mahoney
Loc: Indiana
Reg: 02-13-03
04-03-20 10:50 AM - Post#2790219
    In response to mr_mahoney
Could this be a common thing form the torque converter draining down?
https://www.stovebolt.com/ubbthreads/ubbthreads .php?ubb=showflat&Numb er=1068461
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
04-03-20 10:59 AM - Post#2790222
We have called it "burping." Don't know the cause, but mine does it too.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
drtyler
drtyler
Loc: Georgia
Reg: 05-06-10
04-03-20 11:00 AM - Post#2790223
That's what it sounds like to me. How long between parking and driving when you found a lot of fluid on the garage floor?
mr_mahoney
mr_mahoney
Loc: Indiana
Reg: 02-13-03
04-03-20 11:10 AM - Post#2790226
    In response to drtyler
It had not been ran in awhile. Sounds like it just burped. My 80 yr old mom will be thrilled to know it's not broke. It is her car from youth and she has been anxious to ride in it again.
mr_mahoney
mr_mahoney
Loc: Indiana
Reg: 02-13-03
04-03-20 11:11 AM - Post#2790227
Should I refill with Dextron III trans fluid?
drtyler
drtyler
Loc: Georgia
Reg: 05-06-10
04-03-20 11:14 AM - Post#2790228
Yes, Dexron III or the latest replacement Dexron VI is fine. I use both in '54 Powerglide and they work fine.
04-03-20 11:30 AM - Post#2790231
Here is a good thread on this. Gene Schneider is known as a VCCA expert on these cars. He does post here occasionally as Chev Gene. I am also going to make this a sticky.
29-41, 42-48, 49-54 Moderator
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-03-20 12:34 PM - Post#2790239
This seems to be especially common with the Tri-Five, Powerglide cars. They say to run the transmission about one quart "low". There are one way valves that can be installed in the cooler lines that seem to have limited success. Others say wear and tear on the hard parts, that are getting harder to find replacements for, add to the "burping". Many classes in drag racing now require a "burp tank" connected to a transmissions vent, to keep trans fluid off the track; this might be another approach, though not a cure. I think it's something you just have to live with, and try to mitigate as much as possible. I am Butch/56sedandelivery.
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
04-03-20 12:56 PM - Post#2790240
That's a very nice car
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2017 Silverado LTZ 6.2
2020 Blazer Premier
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
04-03-20 03:39 PM - Post#2790253
    In response to Dave in VA
I agree.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-04-20 12:13 AM - Post#2790274
    In response to hpva
Yes, very NICE car you have there. It reminds me a little of all the work and time "40grit" has put into his 53 Convertible. Same color (more or less), L-O-T-S of body and paint work, and a ton of time. Course his is rodded, while yours is stock. You both do fantastic work, just the same!
04-04-20 06:35 AM - Post#2790279
Mahoney, what's the history of your beautiful car? I see your old pictures... did it come from your family?
clyde hammer
Reg: 10-17-09
04-05-20 03:15 PM - Post#2790395
Mine does that also. Just something I live with and add fluid as needed. I've discovered if I run it a quart low it does help. I check the stick after I warm it up and add accordingly. Running it a quart low I don't lose much fluid as apposed to bringing it to the FULL mark.
04-08-20 06:41 PM - Post#2790685
He said it was his mothers car from her youth. I’m sure he’d be glad to expound on that. I’d like to hear about it myself.
1957 Cameo Carrier
UnclBob
UnclBob
Reg: 07-01-12
04-09-20 03:34 PM - Post#2790765
    In response to clyde hammer
A few years ago, Hemming Motor news ran an article explaining how to install a vent someplace on the power-glide. I loaned it to a friend who lost the issue. I am tempted to replace mine with a 700 R4, if I cannot find the venting article.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
04-09-20 08:05 PM - Post#2790776
    In response to UnclBob
A friend purchased a 57 with thee part mentioned installed. It did not work but the installer put it in the wrong place, the new one stopped the problem.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
04-09-20 10:20 PM - Post#2790786
Don't know if you looked at this.
Execution time: 34.14 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 AM
