Username Post: Frame crack        (Topic#360374)
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-02-20 03:24 PM - Post#2790141
I to stop looking so close. Cleaning off the rust I found a frame crack over the rear spring rear mount. The crack is only on the side of the frame, not on the outside top or bottom. The white stuff is Hirsh rust remover I plan on stop drilling the crack then welding a 1/4 “ flat plate doubler about a foot long. What do you think on how to proceed? I am working in my home garage and can’t fabricate anything. Advice please.
Thanks guys
Attachment: FC4C8928-0BEC-47F0-8B18-FD93ED8CF19F.jpeg (143.76 KB) 19 View(s)
Attachment: D68F1FDC-3FBC-4BC1-AC39-642E6C25A68E.jpeg (158.84 KB) 9 View(s)
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
04-02-20 04:28 PM - Post#2790149
    In response to Doug52sedandelivery
Grind all the crud off, down to bare metal, to see what you really have. There could be more damage.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
04-02-20 05:00 PM - Post#2790152
    In response to tommy49
I'm with Tommy get it clean so you can really see what you have drill your holes and then weld it up.
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-02-20 05:45 PM - Post#2790160
    In response to Mike JW
Thanks guys, I will take your advice and get my grinder out.
junky
Loc: Northeast CT
Reg: 06-27-10
04-02-20 10:36 PM - Post#2790177
I have found that an air powered needle scaler cleans rust away faster and easier than using a grinding wheel. Also a lot easier to control on the surfaces you are working on.
tommy49
tommy49
Reg: 09-28-12
04-03-20 05:10 AM - Post#2790186
    In response to junky
The needler will clean crud and rust off, but, in my opinion, don't leave the best surface for welding, especially in a crack.
Tommy
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
04-03-20 05:35 AM - Post#2790190
Pretty sure that's not just a crack. It's a rusted out section. I had a similar looking area on my frame near the front by the cowl. There was a mouse nest in that spot. Had to cut out and replace with a section about 1.5"X 10-12".
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
04-03-20 04:55 PM - Post#2790257
    In response to johnwd98
When metal cracks, it is usually the result of continuous flexing that work hardens the metal. Eventually the metal becomes brittle resulting in the crack. Welding the crack may very well not solve the problem as the material is now damaged to the point it will merely crack again next to the weld.
If the damage is the result of rust behind the panel it really needs to be opened up anyway in case the damage is bad enough to effect the integrity of the panel. An experienced welder should be able to give you advice on what they can do with it. You obviously have been down this road before with the area up front.
Good luck, I hope that is the only trouble spot. I will say, on my '53 it was so bad I bought a parts car in order to get a good frame.
Just Slightly Abrasive
Edited by 40grit on 04-03-20 04:58 PM. Reason for edit: No reason given.
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-03-20 05:08 PM - Post#2790260
    In response to 40grit
Thanks everyone. I am going to start by sand blasting the area and see what turns up. It may just be rot rather than a fracture as is pointed out. It just never seems to end with this 52.
Thanks again
Doug
Mike JW
Mike JW
Reg: 01-19-06
04-03-20 07:33 PM - Post#2790268
Good Luck with what ever it takes.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-04-20 12:09 AM - Post#2790273
OOPS!!! Posted to the wrong thread.
I am Butch/56sedandelivery.
Edited by 56sedandelivery on 04-04-20 12:10 AM. Reason for edit: No reason given.
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-04-20 12:57 PM - Post#2790300
Well I cleaned up the “crack” which turned out to be rot. It seems to be solid at the top and the plate riveted to the frame for the spring mount. My only choice is to weld a 1/4” flat plate to the frame 12” long by height of the frame. Anything else is beyond my capabilities and funds, so short of giving up ( which won’t happen ) I plan on doing that. I will probably do the same on the passenger side.
1 last question, would you rest the car on the frame in front of the forward mount for the rear spring mount before welding or doesn’t it matter? Currently it sitting on the tires.
Thanks again for everyone’s advice. BTW sand blasting with my small blaster did nothing so I grabbed my grinder.
Doug
Attachment: 7D76394B-8AF0-4D8C-A9A3-BC9F282C22B3.jpeg (125.54 KB) 13 View(s)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
04-04-20 01:42 PM - Post#2790302
I've nothing to offer you but encouragement. I have so much respect for people who know how to do this kind of metal repair! I'm looking forward to seeing how you make out.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
04-04-20 02:06 PM - Post#2790304
    In response to dsacton
I’m open to correction but here’s what I’d do: cut away until you’ve got very solid metal in a simple shape. Reproduce the shape with cardboard and trim until precise. Trace to 1/8 plate and cut out, tack a tab on it to hold it in place, bevel it and the frame and fill it in with as much speed as possible while still getting good penetration. Do not super heat the metal there. I’d probably use .025 wire and go as fast as possible. Get your face right in there and have at it. Best of luck
And it never ends with any of these cars haha. Good luck
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
tommy49
tommy49
Reg: 09-28-12
04-04-20 02:14 PM - Post#2790306
If you have a welder and a grinder, it's a very doable repair. Straight cuts to remove the rot, straight cut pieces to fill the spaces, weld in. Removing the rivets & brace would be needed. This is where skills are learned.
Tommy
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-04-20 04:31 PM - Post#2790315
    In response to drew1987
Drew,
You wouldn’t use 1/4” plate?
Thanks,
Doug
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-04-20 05:18 PM - Post#2790321
Tommy,
Thanks for the advice. Would keeping the weight on the spring while I weld set up a later stress point or doesn’t it matter?
Doug
40grit
Reg: 07-08-13
04-04-20 06:39 PM - Post#2790329
It is good to use a material similar to the frame itself. It is probably 11ga which is 1/8 inch. I certainly would go no thinner though.
tommy49
tommy49
Reg: 09-28-12
04-04-20 07:09 PM - Post#2790332
  • Doug52sedandelivery Said:
Tommy,
Doug
Shouldn't, frame's held in place with body mount bolts, but While up on jack stands, put a floor jack under the rear axle, just to take that weight off.
Tommy
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
04-05-20 08:42 AM - Post#2790365
I would try to lace up the hole then add a piece of angle iron, drill holes in the a iron where the rivets are so it sets flush. ?
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
drew1987
drew1987
Reg: 02-23-14
04-10-20 05:20 AM - Post#2790796
Drew,
Thanks,
Doug
I personally always try to match materials. all of this stuff flexes, and quarter plate would much less so, which would cause a problem
Speed is important too, so as to not over heat, and 1/8 with 025 wire would be nice and fast
You got this =) if you dont have a welder and a grinder, time to get one (harbor freight is just fine for the DIYer starting out, if you have extra money get a miller or whatever)
get a much of scrap from your local steel supplier and do some practicing and youtubing
Member:
drew1987
drew1987
Reg: 02-23-14
04-10-20 05:30 AM - Post#2790798
https://www.lincolnelectric.com/en-us/Equipment/Pa... if you wanna spend $1200 but research "commercial power"
Cheap but 240v https://www.harborfreight.com/welding/welders/170-...
Happy medium? https://www.harborfreight.com/welding/welders/mig-...
Member:
Edited by drew1987 on 04-10-20 05:34 AM. Reason for edit: No reason given.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
04-10-20 11:09 AM - Post#2790825
have you cut that section out. I have good frames we are using for parts.
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-10-20 02:31 PM - Post#2790837
Drew,
I have a MIG from Eastwood. Haven't got to it yet. Still working on inner and outer rockers try to get them to fit to the door. Still have a drivers rear front quarter panel to weld in.
Thanks for your help
Doug
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-10-20 02:34 PM - Post#2790838
    In response to cbmkr56
cbmkr56,
I haven't gotten to it yet. I am still doing other things first. Should get to it shortly. It seems to be paper thin above the area I already cut out so I still need to grind some more. Its good to know you have frame parts.
Thanks,
Doug
drew1987
drew1987
Reg: 02-23-14
04-10-20 04:03 PM - Post#2790847
Oh good!
Yea maybe nice to cut a rectangle out an inch higher or so
Good luck
Member:
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
04-15-20 02:14 PM - Post#2791219
Well here is my finished product. Not pretty welds but solid and good penetration. The frame metal was around 13 gauge with the rust cleaned off. I mic’d it to check. I used 11 gauge to make the patch. Had trouble when puddle came to a dimple in the frame from rust. It would blow through. I added the angle iron because the frame in that area by the spring Mount was rotted. Seems solid now when hit with a ball peen. I am happy with it now.
Thanks for all the advice and suggestions from everyone.
Doug
Attachment: 59EEC154-0864-4EF6-A151-AF6B459C1AB9.jpeg (110.37 KB) 10 View(s)
Execution time: 0.135 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:15 AM
