Username Post: Decarbonizing        (Topic#360360)
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
04-01-20 01:26 PM - Post#2790015
I am getting a good deal of spark rattle (pinging) when the engine is warm and under load. Experiments with timing have done little good: when I back timing off to the point the spark rattle diminishes, so does the power. I have started burning 110-octane race gas and that has helped but man that stuff is expensive.
What I need, I think, is what the British motorcycle manufacturers used to call "De-coking". Many years ago, Sunoco used to sell a product called Suntune which, when added to a running engine through the carburetor, would cause large clouds of black smoke to exit tailpipes, theoretically getting carbon off the tops of pistons.
I realize the right way to do this job is to pull the heads and (maybe) the pistons. I don't want to pull an engine apart that has been together since December 1964. Does anyone sell a consumer-lever "decarbonizing" product that actually does some good?
1953 3104 1/2 Ton Truck
1965 Impala SS 327/M20
1965 Chevelle SS 327/M20
VCCA #47487
AACA #446449
ALPCA #12906
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
04-01-20 02:40 PM - Post#2790020
    In response to bajones238
I'll probably get snickers on here from some, but Marvel Mystery Oil seems to help my fuel system and upper cylinders. Certainly makes the engine idle smoother and has helped my gas mileage whenever I use it. I keep complete fuel logs on my daily drivers.
Having said that, I don't know of any decoker. Although I did produce a lot of smoke the time I filled with diesel rather than gasoline. (And no, it wasn't from a farm tank... )
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
04-01-20 03:23 PM - Post#2790023
make sure your vacuum advance is connected to manifold vacuum
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
04-01-20 03:28 PM - Post#2790025
    In response to aghaga
bajones238 - - - Have you looked at Sea Foam? Have heard it will do what you are looking at needing to remove deposits. May be worth looking at. Do a Google search.
Chuck
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
04-01-20 03:47 PM - Post#2790026
Way back in the day we used to take a Coke bottle full of plain water and slowly trickle it into the carb while holding the throttle open just enough to keep it from stalling out.
A whole lot of black carbon deposits would spit out the tail pipes during this, but it would run a little better afterwards.
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Rick Dorion
Rick Dorion
Loc: Accord, NY
Reg: 09-21-12
04-02-20 02:23 AM - Post#2790059
    In response to steve65
Second the water treatment. Use a spray bottle to better control the amount of water being injected.
1967 Belair - perfect floor, frame and pinchwelds. Oh boy.
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
04-02-20 06:44 AM - Post#2790077
I've had good success using GM top engine cleaner. I purchased it at my local GM dealer parts counter. You gradually pour it into the carb while the engine is running. You'll need to hold the throttle part way open to keep it from stalling.
Shut the engine off and let it sit for half an hour then restart. Massive clouds of black smoke will blow out of your tailpipes, which I assume is the dissolved carbon from your combustion chambers.
Hope this helps.
Johnny
1965 Impala SS
505/4-speed/3.90
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
04-02-20 07:25 AM - Post#2790082
    In response to Johnny468
Thanks for the great suggestions guys. I'll try the water first, then the Marvel, then the GM stuff if nothing else works and if I can find it. Will report back!
VCCA #47487
AACA #446449
ALPCA #12906
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
04-02-20 09:29 AM - Post#2790099
Sea Foam is a good idea. That's what it's formulated for, but you could also add a gallon of methanol to the tank. A methanol flame consumes carbon.
Verne
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
04-02-20 09:45 AM - Post#2790101
Way back almost 40 years ago I remember being at the local Mustang parts/cars for sale and restoration place where there was a rat bagged Super CJ '69 they were revving up while pouring ATF down the throat of the big Holley 4150.
Tons of smoke and crap belching out.
It was red with "for sale cheap" painted on the hood.
Not no more these days.
Ryan
Build date Dec. 21 '64 Oshawa
Texasray
Texasray
Reg: 11-01-16
04-02-20 10:55 AM - Post#2790110
    In response to Oshawa65SS
Yeah, we use to pour ATF down the carb for 20 seconds or so during the '70's. It causes alot of smoke, but the cleaning action of the ATF is what was supposed to work. ATF is not the same anymore, so...? Another trick is to pull the spark plugs and soak each cylinder over night with AFT to loosen the carbon. One of my friends dad did this to his 6 cyl. Ford truck. It would stop the ping for about 6 months and he would do it again.
Be sure and rotate the cylinders slow with the spark plugs out to get all the liquid out the next morning, don't want any bent rods.
I would try the Marvel, then the GM top engine cleaner, but if you soak it I bet the Marvel oil would do the trick.
Sam
impala
impala
Loc: Pittsburgh, PA USA
Reg: 07-13-00
04-02-20 02:36 PM - Post#2790138
I would try the water first too because what you want to achieve is to create steam and what better way to do that than with water. An engine that has been run a while with a blown head gasket where coolant has gotten into a combustion chamber will do the job you're trying to do.
impala
61 Impala Convertible, AACA Senior Grand National
99 Jaguar, XK8
13 Avalanche LTZ
18 Equinox
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
04-02-20 05:59 PM - Post#2790162
    In response to impala
Years ago working at a Chevy dealer it was always the top engine cleaner you poured down the carb. If you can find it follow directions re: run thru 1/2 can then pour it in fast to choke & stall the engine. Important to let it sit ("hot soak"). Last time I looked all I could find was an aerosol spray form. Otherwise water is probably the best but ATF & Marvel both work well in that form/application. They all work much better than any of the in tank additives.
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
04-06-20 08:58 PM - Post#2790531
    In response to Gaspains
This is what I've done in the past , I'm a big fan
of marvel mystery oil.
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:38 AM
