Username Post: 64 rear axel bearing        (Topic#360347)
sanee64
Loc: atlanta ga
Reg: 04-05-18
03-31-20 10:10 AM - Post#2789901
one side of mine started leaking and ill need to replace. I know i need to order the bearing and lock ring but ive contacted classic industries and show cars but no one is picking up due to covid.
summit or jegs dont seem to have this.
my local napa had it but it was something totally different
seems a bit pricey for local store
https://www.oreillyauto.com/detail/b/national-292 9...
anyone know where i can get this?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
03-31-20 10:52 AM - Post#2789905
    In response to sanee64
Read this - check DZAUTO(Tom) pictures of the bearings 55-64 bearings..in the first part of the post. It shows the correct 58-64 bearing
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
sanee64
Loc: atlanta ga
Reg: 04-05-18
03-31-20 11:16 AM - Post#2789909
    In response to pvs409
thanks for that link!! the bearing on my current axel is definitely not what it should be as it has a single little "rubber gasket" and not a double like what it should be (the rw607)
also i went to rock auto to try and order the part but there are two different ones and im not sure of the numbers at the end. which do i need?
rw607br
https://www.rockauto.com/en/moreinfo.php?pk=183943...
rw607cr
https://www.rockauto.com/en/moreinfo.php?pk=221851...
pvs409
pvs409
Reg: 01-10-05
03-31-20 11:29 AM - Post#2789912
Send the links to Tom(DZAUTO), he is really good about answering.
He will know.
Paul
cowfarmer350
Reg: 02-03-01
04-01-20 02:55 AM - Post#2789955
Looks like the same bearing , just one is National brand and the other is SKF
sanee64
Loc: atlanta ga
Reg: 04-05-18
04-01-20 11:32 AM - Post#2789995
    In response to cowfarmer350
just ordered. big thanks
Member #51
04-02-20 05:15 PM - Post#2790153
Let me run through everything I can think about rear axle bearings.
First, the pictures below are 55-64 axle bearings. The left is 55-56, middle is 57 ONLY, right is 58-64.
These bearings were made by several manufacturers: Green, Delco, New Departure Hyatt, National, BCA, SKF, National and others. SOME had one O-ring, SOME had two O-rings. Some had small groves and thin O-rings, some had big grooves and thick O-rings. Just because a bearing has one O-ring does not mean it is the wrong bearing.
SOME vendors sell separate seals for the bearings (NOT the O-ring). Buying seal is a waste of money, BECAUSE there is no way that a seal will fit the particular bearing which is on the axle. Also, to replace the seal, the bearing must be removed from the axle. To remove the bearing requires destroying the lock ring. LOCK RINGS ARE NOT AVAILABLE SEPARATELY! The only way to get a new lock ring is to buy a new bearing. New bearings come with a seal and a new lock ring. So, it's just as well to replace the bearing if the seal (NOT the O-ring) is leaking. Also, IF a seal is leaking, that is an indication that the bearing is beginning to go bad, so replacing it is good insurance.
Attachment: 5564brng.JPG (1.21 MB) 9 View(s)
Attachment: 5564brngs.JPG (1020.06 KB) 7 View(s)
Member #51
04-02-20 05:23 PM - Post#2790155
The green seal in the bearing below goes toward the OUTSIDE.
I have seen National bearings on Rock Auto for about $65 and SKF bearings for about $100. I seriously doubt there is any difference, except price, between the 2.
Attachment: 100_0994_1_.jpg (87.3 KB) 7 View(s)
Attachment: 100_0995_1_.jpg (90.51 KB) 8 View(s)
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
04-03-20 05:44 AM - Post#2790193
The price difference could be do to one supplying the lock ring and one not. I hanve gotten these bearings both ways but do remember which ones it was.
Member #51
04-04-20 07:33 PM - Post#2790335
    In response to turbo38s10
In over 50+yrs of working on these rearends, I have NEVER, NEVER seen a NEW bearing in the box without the lock ring.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
04-05-20 08:51 AM - Post#2790366
I said that because I did buy one that didn't have it. That said I did get it from a local bearing company who was able to get me one but that was years back.
sanee64
Loc: atlanta ga
Reg: 04-05-18
04-06-20 11:26 AM - Post#2790488
Big thanks to you on this. The bearing that was on the axel was a single seal like the left or middle on and got the national brand like you recommended. Only gripe was i took it to a store next door to my place and they charged me a poopoo ton to remove and put in the bearing. Never again going there.
But everything is installed and just drove the car home. shouldnt have any leakage. Ill deal with the other side next time i have to take the brakes off or something like that.
Big thanks again
Member #51
04-07-20 06:14 PM - Post#2790592
Well, I hate to hear that!
If you want to run the next one to me, I'll be happy to replace the bearing for you-----------MUCH CHEAPER.
If a person brings me the axle is out of the car and a new bearing, I'll replace it on the axle for $20. Takes me about 15min to replace a 55-64 axle bearing if the axle is already out of the car.
sanee64
Loc: atlanta ga
Reg: 04-05-18
04-08-20 04:18 AM - Post#2790626
Ill just drive to visit a buddy of mine thats about 45 mins away as he works for honda and it would be free. Didnt want to drive and thought id give this shop some business. I also thought it would be like $20. Granted he had to saw the bearing off as he went to almost 5k lbs of pressure and didnt come off even with heat. Took about 35 mins tops and charged me $80......jerk
junky
Loc: Northeast CT
Reg: 06-27-10
04-08-20 09:05 AM - Post#2790643
If his press only went to 5,000 pounds of pressure, it wasn't up to the job.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
04-09-20 08:13 PM - Post#2790778
very occasionally one can find the lock ring separate on ebay. i bought one last year. if you have access to a lathe you can make one.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
junky
Loc: Northeast CT
Reg: 06-27-10
04-09-20 09:00 PM - Post#2790779
    In response to 62chevy427
They are made of hardened steel.. You know the type that gun barrels are made of.
Execution time: 0.107 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:30 AM
