Username Post: Thumping sound in 1964 Impala SS dash        (Topic#360343)
rmartin49
Reg: 03-30-18
03-31-20 08:20 AM - Post#2789888
I have a 1964 Impala SS with around 52,000 miles. About the time the speedometer cluster went kaput, I began hearing an intermittent thump/thump sound in the driver side area of the dash when driving. After installing a new cluster and the correct-size speedo cable, I still could hear the sound. I'm told the sound isn't the cable or anything tire-related. Any ideas would be appreciated.
1941srodcoupe
Reg: 07-08-03
03-31-20 04:57 PM - Post#2789934
    In response to rmartin49
Unscrew the speedo from tranny and go for a test ride.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-31-20 05:10 PM - Post#2789935
Did you drop the steering column in order to remove the instrument cluster? There are two clamps that hold the steering column in place from inside the cab. Maybe one of those clamps were not installed correctly.
I have logged many days underneath my dash and behind the instrument cluster. There is nothing back there that really moves except maybe a disconnected wire harness, but you would most likely notice something not working.
Does your car have A/C, if so, maybe a disconnected air duct?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
rmartin49
Reg: 03-30-18
03-31-20 06:31 PM - Post#2789941
    In response to kingkreeton
You've given me a couple of somethings to investigate. I appreciate your willingness to help me troubleshoot this sound!
rmartin49
Reg: 03-30-18
03-31-20 06:33 PM - Post#2789942
And, yes, the car has factory A/C.
04-01-20 06:16 AM - Post#2789965
I once found a 5 foot long black snake up under the dash of my '53 Chevy. The car had been stored for years, and one day I pried open the pass door, sat down, and opened the glove compartment to see what it held. A big, fat defroster hose was hanging down into the glove compartment, and when I reached in I brushed my wrist against it. That big, fat defroster hose then muscled up and slithered deeper into the dash and I rocketed out of that car in record time.
impala
impala
Loc: Pittsburgh, PA USA
Reg: 07-13-00
04-01-20 07:49 AM - Post#2789975
Does the thump sound the same as you accelerate or does it increase in frequency? Did you also repalce the whole speedo cable, housing and cable or just the cable?
impala
61 Impala Convertible, AACA Senior Grand National
99 Jaguar, XK8
13 Avalanche LTZ
18 Equinox
rmartin49
Reg: 03-30-18
04-01-20 11:36 AM - Post#2789996
    In response to impala
Starts within a few miles of driving. Any speed. Straight roads, curvy roads, turns. Same continuous thump/thump sound until the car is turned off.
I furnished a new OER speedo cluster and new, SS correct OER speedo cable (no other replacement parts) to my trusted, gray-beard mechanic who is quite familiar with the '64 Impala SS. Mine is a matching numbers 409.
Thanks for your intetest. LOVE that white '61 in your post info!
Edited by rmartin49 on 04-01-20 12:04 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
04-02-20 05:31 AM - Post#2790067
You say same thumping until the car is turned off, you mean it thumps with the engine running and the car stopped? If yes, it’s most likely the exhaust touching something after it warms up and expands?
Member #2194
rmartin49
Reg: 03-30-18
04-02-20 05:43 AM - Post#2790069
    In response to DonSSDD
Let me double-check that. Can do it tomorrow. Thanks for the lead.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
04-02-20 08:06 AM - Post#2790089
Never had a speedo 'thump' (my definition of 'thump') upon failure. They made a much higher pitched (closer to buzzing/rattling and really loud and annoying) noise. Also, if it is 'thumping' at a stand still, can it be the speedo?
Could it be something hitting the firewall?
If you haven't already:
Next time it is 'doing' it at a stand still, look under the hood and under the car for something banging. Rev the engine, see what that does. Can 'hear' where it is coming from?
Just trying to be helpful.
Pete
rmartin49
Reg: 03-30-18
04-02-20 08:14 AM - Post#2790090
    In response to japete92
Thanks much. I'll try anything. Uh, except that black snake thing. 😅
junky
Loc: Northeast CT
Reg: 06-27-10
04-02-20 01:40 PM - Post#2790132
Brake booster loose on the firewall? Bad mount under the cowl? Time to think outside of the box! There is a plastic duct that goes over the steering column and connects to the left side air conditioning duct. It is a friction fit to the other ducts, and it could be loose. You were not clear if it still makes a sound when the car is parked or not. Is it possible that there is something loose in the steering column, or a bad rag joint? Just throwing out different things that I would be looking at if it were my car.
rmartin49
Reg: 03-30-18
04-02-20 01:58 PM - Post#2790133
    In response to junky
Thanks, Junky. Appreciate you weighing in. We'll work through your ideas and get back to you. Thanks again.
junky
Loc: Northeast CT
Reg: 06-27-10
04-02-20 06:42 PM - Post#2790167
If you need more help, ship the car to me with the title, and I will find the problem, and road test it for a year or two, and then send it back to you. That's is what friends do for friends..
rmartin49
Reg: 03-30-18
04-03-20 05:49 AM - Post#2790194
Love your spirit, Junky, but Roscoe ain't going nowhere! He's not complaining about my thumps, squeeks and groans, so I'm cutting him some slack. Thanks to all who responded to my post. Going off the grid now. Have as good a weekend as possible with everything going on, my friends.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
04-03-20 05:57 AM - Post#2790197
Let us know what you find. Have a good weekend.
Shane
64 Impala SS:
4 Speed Muncie
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
04-03-20 07:40 AM - Post#2790206
Center carrier bearing WORTH A LOOK SEE
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
04-03-20 08:16 AM - Post#2790209
    In response to 69_BOWTIE
O.K. I can't resist anymore.
Have you found any eggs on the floor? Sounds like the Easter bunny to me.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
04-03-20 03:46 PM - Post#2790254
    In response to acardon
Funny I was thinking Thumper was at again!
Execution time: 0.155 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:33 PM
