Username Post: Power source for electric choke.        (Topic#360333)
kajun
"5th Year" Platinum Supporting Member
kajun
Loc: Prairieville, Louisiana
Reg: 07-03-05
03-30-20 06:58 PM - Post#2789852
I have the Classic Update Kit (510372) for my 66 Impala. I a long way from finishing my complete kit but I have installed the Dash Kit, Instrument Kit, and Engine kit. I don't have the front cap on so I do not have the front light harness or the rear body harness installed yet. So for that reason I don't have all of the fuses in, just what powers the engine up. I want to run my motor every now and then. It starts, runs, and stops just fine, but I don't have power to the electric choke wire or the temp sender (could be other stuff too).
I don't think it's a grounding issue, but just in case, I'm using the negative post on the battery for a ground and still not getting 12 vdc.
What fuse powers the choke and temp sender?
Or is it something else?
Eric
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-01-20 09:52 PM - Post#2790045
    In response to kajun
Put the gauge fuse in.
Donny
kajun
kajun
Reg: 07-03-05
04-02-20 05:39 PM - Post#2790159
    In response to aawtech
Thanks Donny, that was it.
Was there supposed to be a wiring diagram in my 510372 kit?
Is there a list that tells me what circuit each fuse powers up?
Eric
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-05-20 09:10 PM - Post#2790425
Yes, that one does have a schematic in it. What are you wanting to know? The main 510372 instruction set has a general schematic.
Donny
kajun
kajun
Reg: 07-03-05
04-06-20 12:57 PM - Post#2790498
I guess what I'm looking for is either of these:
A list of what every fuse powers up.
OR
A list with the power source for anything that may be missing it's voltage.
This is a perfect example. I'm looking for the power source for the electric choke. Try as I could I could not find anything that led me to the "GAUGE" fuse. (but I'm not the sharpest tool in the shed). I saw wires that led to terminals on the fuse block. But I did not see any connections from the terminals to a particular fuse, and very little on the electric choke.
I know once you get everything installed and if you need to find missing voltage, just look for a blown fuse. I'm years away from getting everything installed.
A simple list of what every fuse powers up would do it. Then I would not have to ask you my lame questions.
I really appreciate your help on this board Donny. I read every one of your responses, even if if doesn't pertain to any situation I'm in.
Eric
Execution time: 0.262 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:14 AM
