Username Post: Starting issue        (Topic#360320)
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
03-29-20 03:57 PM - Post#2789753
Good battery and clean connections, but only get an intermittent clicking and tickle of the starter when I turn the key. Not sure if the problem starter or a bad ignition switch. Any ideas? Jumping doesn't help, by the way.
03-29-20 04:04 PM - Post#2789755
    In response to C10KLee
Load test the battery, check the cables and ground also.
03-29-20 04:31 PM - Post#2789757
tap the starter with a hammer
03-30-20 04:15 AM - Post#2789778
    In response to bobb
If it's clicking, the ignition switch is sending 12V to the starter solenoid. The solenoid switches to battery 12V to turn it over. Tap it with a hammer as suggested. Clean the frame to ground good. Check the engine to body and engine to frame grounds. How old is the starter? A local parts stores can check it too. I've seen batteries have 12V and low amps. What's the batter volts? Do volts drop if someone turns the key?
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
03-30-20 09:59 AM - Post#2789809
IF the battery is good, then it's the starter solenoid. Specifically, the "internal", positive posts inside the solenoid. If you're cheap, and don't want to buy a new solenoid, then remove the plastic/balklite cap, and flip the post around 180 degrees; it will be obvious to you by the arcing wear to the post. Then it can start the arcing wear all over again. The big copper washer is what actually makes contact with the posts, but only one post wears. I can't tell you how many times this has happened to me over 50-55 years working in this hobby. I am Butch/56sedandelivery.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
04-10-20 06:08 PM - Post#2790862
Yeah, pretty sure it's the starter, or at least the solenoid. I have done that contact workaround before. Probably just get a new solenoid next week, if not a new starter altogether.
Execution time: 0.415 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:17 PM
