Username Post: ADD A REAR SWAY BAR        (Topic#360294)
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-27-20 03:42 PM - Post#2789577
Anybody add a rear sway bar to their stock 53-54 Chevy?Pictures of their setup.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
03-27-20 05:11 PM - Post#2789583
    In response to hpva
I've got a rear sway bar on my 50. But don't have any pictures. I'll try and get pictures tomorrow never thought about taking them when I did it.
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-28-20 05:40 AM - Post#2789611
    In response to Mike JW
Does it help eliminate rear end sway?
03-28-20 05:56 AM - Post#2789612
    In response to hpva
Yes, big improvement on my 51.
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
03-28-20 06:25 AM - Post#2789617
I installed a front mustang sway bar on the rear of my '47 Fxxd years ago. I installed it upside down and backwards to make it fit.
What a difference it made on that car.
Just Slightly Abrasive
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-28-20 08:22 AM - Post#2789625
    In response to 40grit
I bought a rear from Heidts last year that's for 49-54 Chevys plus it said it fits many other makes.Just waiting for my friends lift to be available.It will be easier to install with the car up in the air.
Mike JW
Mike JW
Reg: 01-19-06
03-28-20 11:01 AM - Post#2789636
    In response to hpva
Tried to get some pictures for you but came out really bad laying on the garage floor shooting up under the car. I will say it's well worth doing improved the handling of my car allot sorry about the pictures.
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-28-20 01:40 PM - Post#2789646
Thanks anyway.Thank you all for your replys.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-29-20 11:39 AM - Post#2789728
    In response to hpva
I would also be interested in photos or examples of the rear end sway bar.
Dean50
03-29-20 12:19 PM - Post#2789733
    In response to hpva
you must have a front bar that is bigger than the rear. it will reduce body roll.
Mike JW
Mike JW
Reg: 01-19-06
03-29-20 07:07 PM - Post#2789767
    In response to Dean50
Finally got some pictures I could see and post. This is a 10 bolt chevy out of a S10 4x4 pickup. And if I remember right I took the sway bar off the same truck. Hope this helps.
Attachment: IMG_0560.jpg (2.11 MB) 13 View(s)
Attachment: IMG_0562.jpg (1.86 MB) 7 View(s)
Attachment: IMG_0578.JPG (1.81 MB) 10 View(s)
Attachment: IMG_0580.JPG (2.07 MB) 9 View(s)
Attachment: IMG_0581.JPG (1.76 MB) 12 View(s)
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-30-20 05:17 AM - Post#2789782
Thank you for the pictures, yes it helps.
03-30-20 07:59 AM - Post#2789795
    In response to hpva
it is better to have the mounting points on the rear end as far out as possible. factory mounts may be a compromise.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-30-20 08:00 AM - Post#2789796
That looks First Class, Mike.
Dean50
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
03-30-20 11:53 AM - Post#2789815
That's the same bar I'm going to use. Thanks for posting the pictures!
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
grs
Reg: 07-04-14
03-31-20 08:30 AM - Post#2789889
    In response to hpva
It is not a sway bar. It is an anti sway bar. It stops the swaying of the car.
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
03-31-20 11:26 AM - Post#2789911
    In response to grs
Understood,just one less word to type.
40grit
Reg: 07-08-13
03-31-20 05:31 PM - Post#2789937
    In response to grs
Yea, And I don't have a hot water heater either but sometimes criticism has no benefit.
Mike JW
Mike JW
Reg: 01-19-06
03-31-20 06:14 PM - Post#2789940
I'm glad the picture's helped. You won't regret putting a sway bar on you car. It really does help.
Execution time: 0.14 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:28 AM
