Username Post: recommendations on workshop mig welder        (Topic#360277)
WillieOsgood10
Reg: 03-25-20
03-26-20 01:28 AM - Post#2789480
Hi,We are looking to purchase a mig welder for general work in our workshop.. can anyone recommend a good quality mig welder that will last.. have a budget of maximum 1600 pounds to spend..
will be used for welding mild steel only..
will mostly be used for light box and flat plate.. but rarely heavier jobs will be done on heavy plate of 10/12 mm
WagonCrazy
WagonCrazy
Reg: 06-07-05
03-26-20 07:27 AM - Post#2789489
    In response to WillieOsgood10
Typically the 110volt welders can only due up to 3/8 inch thickness (about 9mm). When you get thicker than that, you should consider a 220volt welder.
Lincoln, Miller, etc.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-26-20 08:01 AM - Post#2789490
    In response to WagonCrazy
https://www.eastwood.com/eastwood-mp250i-multi -pro...
https://store.cyberweld.com/hoir230migwe.html
https://www.weldingsuppliesfromioc.com/lincoln-pow...
Edited by grumpyvette on 03-27-20 07:25 AM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-31-20 09:13 AM - Post#2789894
    In response to grumpyvette
WELL? what did you decide??
Execution time: 0.238 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 PM
