Username Post: Do I need a Brake Switch (again) ?        (Topic#360262)
CraigG-20
Reg: 05-01-08
03-24-20 07:31 AM - Post#2789362
Hi All, I have a 1995 G-20 van with 212,000. I have owned it for 20 years, and in that time have replaced the brake switch 4 or 5 times, most recently in April 2017, only 6,000 miles ago. It is replaced because the brake lights don't come on.
I noticed recently that I had a hard time moving from Park to Drive after starting the van. The only thing that works consistently is to push the brake pedal very hard. On a recent drive while using cruise control, when I tapped on the brake to disengage, nothing happened. Finally, I found out yesterday that my brake lights are not coming on (but the turn signals and flashers work fine). The lights do flash momentarily when pressing down hard, which I can only do when totally stopped.
It is hard to believe I need another switch, but is that what I should be looking at? On the last repair, I believe the garage also changed out the wiring connector bundle.
If so, what brand do you recommend to buy?
Thank you, Craig
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-24-20 08:27 AM - Post#2789367
    In response to CraigG-20
Sure sounds like you need a switch.
Replaced quite a few of them.
Get oe if you can.
Others I have used last about a year or so
Old School GM fan FOREVER
CraigG-20
Reg: 05-01-08
03-24-20 10:43 AM - Post#2789381
    In response to rockfangd
OK - BTW, the 2017 switch was replaced at a Chevy service center, so I would assume was OE. If I can't get OE I will probably go for AC Delco. Thanks.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-24-20 07:48 PM - Post#2789403
I would assume that if it were a adjustment issue you would have had it for awhile now.
Unfortunately I cannot say if that center used a oem part or not.
I commonly see airtex/wells used.
It would not hurt to have a look at the pigtail to the switch itself and the position on the brake pedal lever
CraigG-20
Reg: 05-01-08
03-25-20 12:36 PM - Post#2789453
Thank you, I will pass that information on to the garage and have them look.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
03-26-20 09:26 AM - Post#2789498
I had the same problem and bought everywhere. Oem,different pars stores. Didnt make a difference. It became dangerous getting rear ended. Eventually sold it
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Execution time: 0.197 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:38 AM
