Username Post: Power steering pulley alignment        (Topic#360228)
Ice Cream Joe
Loc: Northern California
Reg: 05-22-17
03-21-20 09:25 AM - Post#2789128
I have a 65 with factory power assist steering.
I took apart the pump and rebuilt it and reinstalled. Now I'm having trouble getting the belt pulleys to line up. The pump pulley is too close to the engine by about 1/4". I can put some spacers (washers) behind the bracket on the block but not that much because the alternator belt is right in front of the pump. a little less than 1/4".
Is there some kind of washer needed on the shaft to stop the pulley from going on too far? There is no washer now but there is a groove. Can I just put a washer in anyway to keep the pulley out further
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
03-22-20 05:36 AM - Post#2789213
    In response to Ice Cream Joe
Was it aligned before you took it off?
Jalapeno
03-22-20 01:07 PM - Post#2789257
pics would help. sounds like a bolt on pulley. i would probly make a washer to fit the shaft by die grinding out a grade 8 washer to fit. hard to say without pics.
Ice Cream Joe
Reg: 05-22-17
03-26-20 08:21 AM - Post#2789491
    In response to Jalapeno
It was but there was so much gunk from the leakage that I didn't see where all the washers and spacers were when I took it apart.
I think I got it with trial and error and an 14 gauge shim behind the pulley
Ice Cream Joe
Reg: 05-22-17
03-26-20 08:23 AM - Post#2789492
    In response to bobb
yep it's a keyed shaft. Found a 5/8" 14 gauge "shim" at the local hardware specialty bolt boxes. It worked great
Execution time: 0.182 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 PM
