Username Post: BCM swap 2015 Express        (Topic#360223)
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-20-20 07:50 PM - Post#2789086
Hi All.
I swapped the BCM in a 2015 Chevrolet Express.
Everything works good but I cannot get the airbag light to go out.
It has to do with the code in the SDM not matching the code in the BCM.
Does anyone know if the number can be reset without replacing or resetting the SDM?
And if not does anyone know who could possibly reset the SDM.
It only has 1 airbag in the steering wheel as it is a cutaway.
Thanks all
Old School GM fan FOREVER
03-21-20 05:57 AM - Post#2789101
    In response to rockfangd
Have you scanned the sirs system to see if there is a code? Could be wrong but I believe the bcm does not control the sirs. Should have lots of time as we are basically locked down, can't even get a take out breakfast here.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-21-20 08:59 AM - Post#2789125
So the SDM and BCM are paired to each other.
If you swap either with a used one it will conflict.
The code is caused by the confliction.
I need to be able to reset one of the modules so it will learn the code from the other module.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-30-20 01:23 PM - Post#2789821
Ok so this morning I swapped the donor bcm back in so I could post the code.
It is the one and only problem with the swap.
The code simply states no communication with the Airbag module.
There is no communication because the primary key sent by the airbag module does not match the one in the Donor bcm.
The code from my Airbag module is 8065.
65_Impala
Reg: 12-29-02
03-30-20 06:52 PM - Post#2789851
They do get matched but i don't know how with a used module. i know the new ones pair themselves but I've read it's a 1-time thing.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-26-20 06:55 PM - Post#2797269
    In response to 65_Impala
Just an update here.
I am not sure why people even sell used modules.
There is no way I can find to repair them.
I am working on something at the moment but am not having luck.
Dealers want nothing to do with it.
65_Impala
Reg: 12-29-02
07-12-20 07:55 AM - Post#2798515
I wonder if a TechII could be used to reflash the module and then it would pair again. I think there are some shops selling/refurbishing modules for exchange purposes and they must get them reset.
But yes, simply selling used modules is rather dumb.
Execution time: 0.118 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:39 PM
