Username Post: oil pressure drop when coming to a stop        (Topic#360214)
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
03-19-20 02:33 PM - Post#2788988
Does anyone know why my oil pressure drops when I come to a stop ?
1950 Chevy Styleline Deluxe 235
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
03-19-20 02:33 PM - Post#2788989
    In response to Larry E
I have a 1969 C10. 350 engine
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-19-20 03:06 PM - Post#2788991
are you stating that at idle you have far lower oil pressure?
are you suggesting that as rpms increase so does the oil pressure?
have you checked your dipstick/oil level?
have you done an oil/filter change recently?
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
03-19-20 03:59 PM - Post#2788998
    In response to grumpyvette
Yes, at idle the pressure is low, about 10
Yes, as I increase speed the pressure goes up to 50
I checked the oil an it looks full.
I will change the oil and filter this weekend and let you know if it makes a difference. Thanks
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-19-20 06:01 PM - Post#2789006
oil pressure is the result of the resistance to oil flow, the low pressure tends to indicate either worn bearings or a well worn oil pump, but could be the result of a loose oil passage plug or loose oil pump pick-up, or defective oil filter.
the bandaid approach would be to swap to a high volume oil pump but that would only temporarily tend too hide the issue not cure it.
in an ideal world , you do a engine refresh with new rings, bearings and gaskets after carefully inspecting and measuring the components of the engine
Edited by grumpyvette on 03-19-20 06:03 PM. Reason for edit: No reason given.
03-22-20 02:24 AM - Post#2789204
is this a recent problem? is your gauge correct? i would suggest an oil test. napa has a kit and its cheap.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
06-14-20 06:39 PM - Post#2796370
    In response to bobb
Does anyone know If I can drop the oil pan without lifting the engine ?
Theres not much space between the oil pan and cross member.
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
06-14-20 06:39 PM - Post#2796371
JimKshortstep4x4
Chevytalk Moderator & "16th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-18-20 04:59 AM - Post#2796629
I have always lifted the engine up as getting the pan to clear the crankshaft has not worked. Also, the fan shroud has to be taken care of.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
doubleE
Loc: Eagan MN
Reg: 06-02-03
06-18-20 09:21 AM - Post#2796655
Just did this on my 72 C10 with the 307 SBC to fix leaking pan gasket with a new one-piece pan gasket. I first pulled the bolts from the front motor mounts and using a floor jack, raised the engine maybe 1 to 1 1/2 inches (until the fan hit the shroud). When I wasn't able to get the pan out I went to U-Tube and found a video that explained turning the crank to a certain position that allowed me to slip the pan out. Don't remember what that was but a search on U-Tube should find it. (Supposedly this works without raising the engine).
Must say the Fel Pro one piece pan gasket was really slick - no leaks!!!
Double E
19Chevy50
19Chevy50
Loc: Wichita, KS
Reg: 06-21-19
06-19-20 10:37 AM - Post#2796710
    In response to doubleE
I have a 350 4 bolt main with a similar problem oil pressure at idle is 20 psi and move up to 45 to 50 while moving. Engine only has about 1500 miles on rebuild. What would be a suggested plan to fix this issue.
Execution time: 0.065 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 AM
