Username Post: Carb fuel pressure        (Topic#360212)
sting199
Reg: 12-12-19
03-19-20 11:04 AM - Post#2788977
Got a 350 in my Corvette with a Holley 670 avenger carb. I am having a terrible time keeping the secondaries from flooding out. Bought a new fuel pump, and put a gauge on it, and getting 10-12# output pressure. The carb is rated input pressure to be 4-6#, so I guess the extra pressure is blowing past the needle valve. (new needle valve and o-ring) Can't find a pressure regulator to work on a carb with this much pressure. Now, I am trying to find another pump that lists the output pressure, without much luck. All suggestions will be well appreciated!
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-19-20 12:15 PM - Post#2788980
    In response to sting199
read the linked info and sub-links
Edited by grumpyvette on 03-19-20 12:40 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
03-19-20 12:21 PM - Post#2788981
A regulator like this would work,
https://www.summitracing.com/parts/sum-g3032?rrec= ...
A factory replacement type pump should have the correct pressure. Something like this,
https://www.summitracing.com/int/parts/crt-m60038/ ...
If you want more flow then you may need a higher performance pump and a regulator.
03-19-20 12:52 PM - Post#2788984
What pump is this? Unusual for a stock mechanical pump to put out that much pressure.
sting199
Reg: 12-12-19
03-20-20 06:26 AM - Post#2789034
It was a carter, M6955, that is only rated to put out 5.5-6.5 psi. Unless my gauge is not any good.
sting199
Reg: 12-12-19
03-20-20 06:29 AM - Post#2789035
    In response to grumpyvette
Looks good, but can't find a regulator that works on a carb system. The only one I have found so far, has a max. input of 6 psi.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
03-20-20 07:26 AM - Post#2789041
Go to RockAuto Home Page
More Information for DELPHI MF0001 Add to Cart
Continue Shopping
1 / 6
Point to Zoom
Part image
Mechanical
Delphi sets itself apart from the fuel pump competition with three words: fast pressure rise. As the OE, Delphi knows how to restore fast-pressure performance and system integrity translating to better pumping through less energy. Their pumps are designed to operate under extreme temperatures, quick engine starts and to avoid low-fuel hesitation, including alcohol fuels and blends.
Features
Increased durability and enhanced stability due to internal springs preventing fuel tube chafing
Better security and durability with multiple redundant buttons on the fuel level sensor
Improved durability with steel plated, all metal internal components
Large volume reservoir maintains sufficient fuel in low fuel situations and vehicle cornering
Longer pump life as a result of a two-strainer system keeping out contaminates
Lower failure rates due to its innovative design and durability.
Reduced potential for greenhouse gas emissions via the EVAP system because of integrated OE fuel vapor pressure sensor.
Guaranteed correct gas gauge reading
Fuel Pump Replacement: Do it right the first time!
Prior to Replacing Pump, check:
Fuel Pump Fuse(s)
Fuel Pump Relay
Voltage at the Pump - test for bad wiring
Voltage drop test - corroded connector, bad wiring
Fuel System Pressure - test for pump pressure being outside accepted range
When Replacing Pump, also:
Replace the Fuel Filter
Replace the Fuel Strainer
Clean / Flush Tank
Refill with fresh, uncontaminated fuel
Package Contents Mechanical Fuel Pump, Gasket, Instruction Sheet
System Pressure 5 PSI
Inlet Outside Diameter (in) 0.375
Fuel Type Gas
Gasket or Seal Included Yes
Inlet Type Hose Bead
Outlet Type Threaded
Outlet Quantity 1
Inlet Fitting Thread Size 5/8 in. - 18 UNF
Average Flow Rating (GP) 40
Alternate/OEM Part Number(s): 6440726, 6440987, 6442080, 6470779
03-20-20 08:01 AM - Post#2789045
I'd check it with another Gage, never used a regulator on any mechanical pump, not even the high out GM pumps. Did you check the float level in the secondaries?
65_Impala
Reg: 12-29-02
03-20-20 09:35 AM - Post#2789050
You must be reading the specifications wrong or the place you shopped had the information listed wrong. There are lots of regulators available that can accept 11psi and drop it to 6psi.
That pump should work fine without a regulator. I second testing with another gauge.
sting199
Reg: 12-12-19
03-20-20 03:19 PM - Post#2789066
Oh yes,, many times. They flood out even when I have the float level as low as I can.
sting199
Reg: 12-12-19
03-21-20 07:42 PM - Post#2789185
    In response to pauldian
That Delphi fuel pump retails for only $10.16, through Rock Auto. Seems to low to be true!
Execution time: 0.168 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 PM
