Username Post: 66 Big block Fan shroud        (Topic#360187)
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
03-17-20 06:55 AM - Post#2788833
Looking to find a 65-70 fan shroud for a big block car.
one on the right.
Ted
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
03-17-20 08:27 AM - Post#2788839
    In response to brickwhite
I think I found one at hubbards..
Plastic but it should work.
https://www.impalaparts.com/6667FSBB/
from this post.
Ted
Edited by brickwhite on 03-17-20 09:07 AM. Reason for edit: No reason given.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
03-20-20 07:25 PM - Post#2789085
This is what I got... fiberglass/plastic of some type. Not abs. Seems to fit well.
Ted
Jonechev
Jonechev
Loc: Cottage Grove,Minnesota. ...
Reg: 05-03-02
03-21-20 05:18 PM - Post#2789170
The one they sent you looks correct for 66. They were not all the same from 65-70. The metal barrel type you showed in the first picture were 1965 design, They were however still commonly found on early 66 model years because in true GM fashion they used up the left over parts from the 65's. Actually it looks like a pretty good reproduction as opposed to the early ones they made years ago. I bought one for my car about 20 years ago and it was awful. Sent it back and found a original.
Execution time: 0.155 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 AM
