Username Post: ring gear install        (Topic#360171)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
03-15-20 03:39 PM - Post#2788709
Hi, What is the correct method to install a new ring gear on a new series 3 12 bolt car carrier? Im not sure how to align bolt holes as it seems the ring gear is not simply going to slide over the carrier. Its as if I would have to lightly press it on. Is this abnormal? The carrier is a new, out of the box. Can someone point me in the right direction?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
03-16-20 08:25 AM - Post#2788769
    In response to 995jim
you can heat it a bit with a propane torch. it will be hot so use gloves. might be a better idea to drop the carrier into the gear so the bolt holes face up. use arp bolts.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
03-16-20 09:15 AM - Post#2788776
    In response to bobb
Yes heat is going to be my method with some temp studs attached to ring gear for alignment as it slides over the carrier. I will probably use a plate and heat source under vs throwing a flame directy to it.
Thanks jim
Edited by 995jim on 03-16-20 09:19 AM. Reason for edit: No reason given.
Texasray
Texasray
Reg: 11-01-16
03-16-20 02:47 PM - Post#2788800
I used a toaster oven back when I worked in a shop. Nice even heating. But use gloves and longer bolts with heads cut off so it is aligned easily when dropped on. Not much time to reposition once they are together.
Sam
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
03-20-20 03:05 PM - Post#2789063
    In response to Texasray
Agree with heating the ring gear...could freeze the carrier too in addition if it's really being fussy.
Execution time: 0.21 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:03 PM
