Username Post: Whats your solution?        (Topic#360168)
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
03-15-20 09:08 AM - Post#2788686
Whats your Solution to those pesky oil leaks from intake manifold bolts? Have used thread sealant a couple of times but still have one bolt that leaks. Any suggestions welcome. Have Aftermarket manifold on a 238. Thanks
Member #409
03-15-20 05:03 PM - Post#2788713
    In response to carolinakid
An aluminum or copper sealing washer under the bolt head can work too.
03-16-20 08:20 AM - Post#2788767
lots of thread sealers are soft set. the oil or gas can soften them more and cause a leak. i would normaly clean the bolt and hole with brake cleaner and use some sort of formagasket.
Execution time: 0.123 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:57 PM
