Username Post: 3 spd - open driveline        (Topic#360078)
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
03-08-20 03:20 AM - Post#2788177
Hello,
I do have a question to a problem I am not sure about.
I changed the original tranny on my 54 inline 6 to a 3 spd out of a 56 chevy to get an open driveline.
Now the thing is, sometimes the 3rd gear just pops out while driving, sometimes more regularly, sometimes a few days not. I cant´t figure out a regularity about that popping out.
Tryed to adjust shifting linkage, but din't solve the problem ...
Any other idea what could cause this? Anyone had this problem too?
Thank you,
Regards from Austria,
Stefan
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
03-08-20 07:11 AM - Post#2788183
    In response to 54er210
2-3 synchronizer is bad. When I was a kid, I replaced the synchronizer regularly. A few "power shifts" and the synchronizer would come a part.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
03-08-20 09:37 AM - Post#2788194
Sometimes a misaligned transmission will cause the it to jump out of gear. I see that Chevrolet had this problem and it is discussed in one of my service bulletins and solved it by shimming the transmission where it botls to the bell housing.
1951 Fleetline Preservation
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-08-20 09:49 AM - Post#2788195
    In response to RAM_51
Hi Ram
How did they know where to shim?
Dean50
RAM_51
RAM_51
Reg: 12-28-02
03-08-20 09:58 AM - Post#2788196
    In response to Dean50
Let me see if I can post that bulletin. Stay tuned...file damage to the previously scanned images....in reviewing what I can see though...a dial runout indicator may be required and there is also a mention of a stronger spring in the box on the column. Just a sec...it's 8 pages.
Attachment: BULLETIN_DR-70_1.jpeg (2.42 MB) 7 View(s)
Attachment: BULLETIN_DR-70_2.jpeg (2.43 MB) 8 View(s)
Attachment: BULLETIN_DR-70_3jpeg.jpeg (2.07 MB) 9 View(s)
Attachment: BULLETIN_DR-70_4.jpeg (1.9 MB) 7 View(s)
RAM_51
RAM_51
Reg: 12-28-02
03-08-20 10:51 AM - Post#2788202
Tha balance of the Bulletin:
Attachment: BULLETIN_DR-70_5.jpeg (2.22 MB) 6 View(s)
Attachment: BULLETIN_DR-70_6_jpeg.jpeg (2.57 MB) 7 View(s)
Attachment: BULLETIN_DR-70_7.jpeg (2.09 MB) 6 View(s)
Attachment: BULLETIN_DR-70_8.jpeg (2.25 MB) 6 View(s)
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-08-20 12:38 PM - Post#2788216
Wow. I guess that about covers that!
Thanks Ram. You have an incredible library.
Dean50
RAM_51
RAM_51
Reg: 12-28-02
03-08-20 12:47 PM - Post#2788218
Seems I have a little more info on the '49s as they were still "shaking out" problems with the new models.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
03-08-20 02:01 PM - Post#2788227
Thank you for this incredible information, need to take some time to read it carefully.
But one question remains when I see this documents, is this a "doing at home job"?
RAM_51
RAM_51
Reg: 12-28-02
03-08-20 02:36 PM - Post#2788229
I suppose someone could do it at home...but keep in mind, I am only trying to indicate that your problem may indicate a misalignment problem or could be something as simple as needing a different spring in the box on the column. Have you looked there? Also, keep im mind that this only addresses a car that is completely the same year [1949] and does not address mixed years [i.e. closed drive line / open drive line].
I had read though some similar information on our vintage Chevrolets jumping out of gear when I worked at an auto craft shop year ago that was associalted with the U.S. Army. I think it was in one of the Service News issues. A guy came in and said that his car was not staying in gear and would "pop-out" at speed. I asked him for more information and learned that he had done some clutch work to it. I asked if he had any parts left over to which he described things that, to me, seemed like shims. He thought they were not important. Maybe wrong, but I summized that that was his problem.
03-08-20 02:53 PM - Post#2788232
Ram, is it your take that the alignment problem originated in the bellhousing?
52BA
52BA
Loc: Newberg, Oregon
Reg: 04-12-06
03-09-20 08:55 AM - Post#2788273
Have you cleaned and put fresh lube inside of the
shift box on the column?
I had the same problem years ago and it was the 60 year old lube would not let the internals in
the box operate freely. Some even add a little
gear oil to thin the new grease some.
Gary
Edited by 52BA on 03-09-20 08:56 AM. Reason for edit: No reason given.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
03-09-20 09:22 AM - Post#2788278
I had a similar problem to this, but with the transmission from the 52. I borrowed a dial indicator and checked the alignment and it was okay. (the engine had been out of the car 3 times.) I rechecked the shift rod alignment, had the transmission apart and replaced the front bearing, needle bearings and thrust washer. Helped a lot but did not cure it. I found that Chevrolet had updated the springs in the shift lever indention's and found a pair of NOS and changed that. The problem finally just went away and I suspect it was the springs for the indents that changed things.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
03-09-20 10:31 AM - Post#2788285
    In response to 2blu52
Ok, thank you.
I will check lubrication first, then the spring, an will see if there is any improvement.
Thanks for your help.
Regards
Stefan
50hotrod
50hotrod
Reg: 07-25-11
03-09-20 11:22 AM - Post#2788287
Hello 54er210,
Have you checked the motor mounts? If things are moving around that could be the problem.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
03-11-20 06:24 AM - Post#2788409
    In response to 50hotrod
When I was a young lad, there was a garage here, that drilled the holes deeper for the detent balls in the side cover. It seemed to work, 55 Years ago.
52 Styleline Fourdoor 62 235 PG
RAM_51
RAM_51
Reg: 12-28-02
03-11-20 11:37 AM - Post#2788437
That seemed to be one of Chevrolet's takes on it. And it seemed to align with the guy that did his own clutch work. Never good to have parts left over. But again all bets are off when you are mixing and matching different drive trains; there are bound to be "bugs" that need to be worked out.
Execution time: 0.123 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:36 AM
