Username Post: 57 210 Quarter Panel Top Fin Molding        (Topic#359932)
Car-nut NZ
Reg: 08-23-16
02-24-20 05:15 PM - Post#2787241
can i make some 42 inch long Nomad Quarter Panel Top Fin Moldings fit on my 210 2 door post sedan. (to replace the short ones)
02-24-20 08:52 PM - Post#2787262
    In response to Car-nut NZ
The short answer is yes. The Nomad molding is just a shorter version of the Bel Air molding. You can actually take a Bel Air molding and cut it down to fit a Nomad because the cross section is the same at the rear edge of the Nomad molding and the rear of the Bel Air molding. The trick will be modifying the 210 quarters to accept the mounting strip pins in either the Nomad molding or a Bel Air molding if that is acquired instead of the Nomad moldings.
1957 Cameo Carrier
Car-nut NZ
Reg: 08-23-16
02-24-20 09:35 PM - Post#2787269
Thanks at 42 inches long they will look great no problem form to fit,thanks again
Execution time: 0.512 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:19 AM
