Username Post: Front fender filler bracket        (Topic#359869)
504chevy2
Reg: 01-11-11
02-19-20 12:15 PM - Post#2786860
Almost ready to start assembling my truck after paint. I have been looking thru an assembly book and seen a bracket that I currently do not have. It is the filler bracket that bolts to the rear of the front fenders.
I have searched for them and found them for sale but not sure if they are a required piece. It’s hard to find pictures online were people reuse them. I was thinking that with that part on and in between the door post and the cowl it would hold trash and water.
Any help or suggestions would be appreciated on weather or not I should use them thanks in advance
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
02-20-20 07:17 AM - Post#2786914
    In response to 504chevy2
I also need this answer. how about bracket for cab seal? Mine were ate up with rot Tom
48 sports coupe
63 C-10 long fleet
17 Tacoma double cab longbed
19 Toyota Rav-4
Been down most all the roads nowhere left to go??
504chevy2
Reg: 01-11-11
02-23-20 05:53 PM - Post#2787149
    In response to RoadRocker
Mine were missing. When I bought the truck it was in boxes basically. So I had to look thru the assembly manual to see how everything goes back together.
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
02-27-20 04:30 PM - Post#2787476
Mine were eat up bad. Do the cab seal clips fasten long filler bracket to fender brace ?? and also rubber seal?? Does door side of cab seal and inside of fender need to be body color as seen from hinge. Lots to consider the truck was taken apart and striped of paint 3 1/2 years ago. Getting closer to crusin every day.
Tom
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
02-28-20 10:43 AM - Post#2787521
I think I know what your talking about. It is a small piece that bolts to the rear top of the fenders and tucks into the cowl. That was probably a way to keep the leaves out of the fenders and as much of us know they don't work very well. This is just my assumption and is not solid proof on this. You could probably just make some if you have some sheet metal and some shears.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
03-01-20 01:04 PM - Post#2787676
    In response to Chevy_Stepside
I have the parts https://www.lmctruck.com/1960-66-chevy-gmc/cbe -196... wonder how clips #14 work and how to install ? Have the filler and right angle piece also part you guys are speaking of. There is also a rubber cab seal. Hope it will fall together when installing fenders. Tom
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
03-22-20 02:41 PM - Post#2789262
Got a chance to work on truck some today. Cab seal mounting bracket goes to fender brace with clips pop them open with pliers rubber cab seal to bracket with weather strip adhesive. Done tight seal. Tom
48 sports coupe
63 C-10 long fleet
19 Toyota Rav-4
Execution time: 0.175 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:17 AM
